FINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting for yay go me pats on the back lmao
You get an atta boyFINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting for yay go me pats on the back lmao
Why are people going with 75-140 when the book says 80-90? Just a question that's all. I just replaced mine with royal purple 75-90. Does sound quieter on the quick trip around the block.
1 qt. do both axles?Syn oil = better friction reduction= ability to add heavier weight oil = less noise lol
ThanksYes 1 quart will do it. Rear is approximately 7oz. Front is approximately 21oz. Double check the capacity in your owner manual but that's pretty close.
I've been considering doing this on mine as well. How cold is too cold for the heavier weight oil? I'll probably never be in anything less than thirty degreesThe higher viscosity oil "clings" to the driveline gears better as it does not thin out as it heats up as bad. This reduces gear gnash, whine, etc. resulting is a quieter differential. If you live is a cold environment though it "can" set up dang near like gravy and be too thick thus depriving the gears of proper lubrication. In this case it would be best to jack up the SXS with tires off ground and warm it up before hitting the trials in the winter. That's why only 80-90 is recommended, it is suitable for almost all conditions but not perfect when it warms up.
Just ordered some.Thanks.FINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting for yay go me pats on the back lmao
Im thinking that the 75w part of 75w140 means that its viscosity is less in cold conditions than 80-90 oil. Right ?I'm talkin 20 degrees F and below for too cold for 145 weight Gear lube.
I assumed that's what you meant, just wanted to be sure. Thank you @JACKALI'm talkin 20 degrees F and below for too cold for 145 weight Gear lube.
Heres a stupid question, is hypoid gear oil what we need?
