P500 Mobile 1 75w140 syn gear oil
265,827
FINALLY got around to changing the dif fluid and definitely made a huge difference in the rearend noise and thats what i was shooting for :) yay go me pats on the back lmao
Glad to hear, 75-140 hushed the noise. That is the exact viscosity I was going to try when I did my first oil change I was going to do both diffs as well.
Moose308
386
289
You get an atta boy
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Just got done with a little ride and wow i thought something was wrong cuz i didnt hear all the clancking noise lol so smooth it crazy just from a little oil change
obxguy2000
obxguy2000
34
25
Sanford North Carolina
Call me dumb, but what is it about changing the dif fluid that cuts back on the noise so much? Just the viscosity being different? How hard is it to change? Is it worth changing right away or just wait to change as scheduled? Mine definitly makes a lot of noise, but since I have nothing to compare it too, I have just accepted it.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Its a 10mm bolt on the bottom i believe a 16 on the side drain The fluid put the 10mm back in fill with fliud till it starts coming out the side 16mm? Bolt hole then plug and tighted very simple
Ross1147
Ross1147
34
106
Florida
Why are people going with 75-140 when the book says 80-90? Just a question that's all. I just replaced mine with royal purple 75-90. Does sound quieter on the quick trip around the block.
265,827
The higher viscosity oil "clings" to the driveline gears better as it does not thin out as it heats up as bad. This reduces gear gnash, whine, etc. resulting is a quieter differential. If you live is a cold environment though it "can" set up dang near like gravy and be too thick thus depriving the gears of proper lubrication. In this case it would be best to jack up the SXS with tires off ground and warm it up before hitting the trials in the winter. That's why only 80-90 is recommended, it is suitable for almost all conditions but not perfect when it warms up.
265,827
Yes 1 quart will do it. Rear is approximately 7oz. Front is approximately 21oz. Double check the capacity in your owner manual but that's pretty close.
1 qt. do both axles?
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I've been considering doing this on mine as well. How cold is too cold for the heavier weight oil? I'll probably never be in anything less than thirty degrees
265,827
I'm talkin 20 degrees F and below for too cold for 145 weight Gear lube.
265,827
I assumed that's what you meant, just wanted to be sure. Thank you @JACKAL
Yes you can actually purchase straight 145 and straight 250 weight viscosity gear oil (think off road racing trucks / Baja type), the multi viscosity synthetics like the 75-145 is the way to go for all conditions.
