P1000m5 Moose blade mount
Strokkerman
Beausejour. Manitoba
Hey guys. First post and new to the forum. Got a 17 10005 Len and just got a moose plow kit from my dealer. I went to install the mounting plate and because I have the le, it has a full aluminum skid, doesn’t appear to me to fit properly. Yes the frt bolts are easy enough but the rear bolts are supposed to go through holes in the frame. To the rear of the mounting plate. The mounting plate I have the rear holes just line up with the aluminum skid. Appears pretty mikey mouse to me. Anyone ever run into this. My dealer told me that moose doesn’t make a mounting kit specific for the le. Don’t want to mount it then end up ripping off the skid. Any help would be greatly appreciated
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,656
Oshkosh, Wi
Why not just drill the holes through the skid plate to allow the plow mount to bolt into the frame?
Reactions: Cuoutdoors
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Post a few pics so what know what you're looking at. I have an LE also. I'd recommend a full uhmw skid plate anyway. I sold my aluminum one and replaced it immediately.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Ran into the same problem, but I had made my own skid plate and just notched it to fit. I did have to remove the floor to complete the install. A few pics...
F3C4F1BB BDF2 4017 A0F0 2BE9A2EDBD3B 433DBAD4 1521 4D33 83F7 B4EF5A4AF491
Strokkerman
66B0254B 354F 47AF A854 2797D2DB8E7C
View attachment 94529 View attachment 94530
So I have it mocked up and I’ll have to notch the mounting plate around the skid plate bolts and washers. On the frt I’m still left with about 3/4” gap between the mounting plate and the skid B3B14C5A 46B6 44B2 8F47 66D06FC0416C
Eltobgi
Eltobgi
4,599
15,186
North Dakota
So I have it mocked up and I’ll have to notch the mounting plate around the skid plate bolts and washers. On the frt I’m still left with about 3/4” gap between the mounting plate and the skid View attachment 94549
It’s been a while but I think I used a jack to close that gap, then installed the bolts. Having someone to assist on this part could save you a lot of time!
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yea I agree I'd jack it up tight and bolt it. I assume there are washers in the middle of the plate causing the issue.... making it flex and close that gap shouldn't cause any issues.
Strokkerman
Gotta up and mounted. Had to grind out plate for washers and then used longer bolts for frame those were fun. All done with. Thanks for your help
Chevy412SP
Chevy412SP
102
126
Western New York
Hey, can you post some pictures of the mount bolted up? Want to see how much hangs down, whether I will have to unbolt it every spring or not for the off-road in season. I had one on my Yamaha Grizzly and the frame caught on everything causing me to constantly get stuck. But it was a pain to bolt and unbolt every year.
