Mounts
chops450
Who makes mirror/light bar mounts that actually fit on these bars. I've already ordered two different kits that don't fit. I have the 1000-5. Any help is much appreciated! Thanks in advance
Reactions: Remington
105,436
Welcome from the the same State your from !👌
Where bouts you from? I live in the Stockbridge area. I ride mostly at my cabin in the Gaylord area.
these are the clamps I’ve used on all my lights
Nilight 90020B 2-Pack (Standard) Mounting Bracket Kit LED Off-Road Light Horizontal Bar Tube Clamp Roof Roll Cage Holder,2 Years Warranty https://www.amazon.com/dp/B0714CYKBJ/?tag=sxsweb24-20
105,436
Here’s a close up that I could get for your. The rubber grommets are used for multiple ROPS and work will all the dimensions of the pioneer
7618D65A AB37 4EB1 8EED 28A71B499F7C
Reactions: GrnP500 and TripleB
CMB
CMB
5,108
55,091
  2. Talon X LV
Axiaalloys.com
renosxs
renosxs
19
32
reno, nv
Just bought 4 of these below and will install this weekend for some rear lights. Will post any issues but expect none due to the grommets. I believe many ROPS are 1.75' while the Honda is 1.78" Never measured both but have seen this while researching spare tire mounts. Please post corrections if found.
[/QUOTE]
chops450
I live in Fowlerville, do most of my riding in St. Helen or out at the sand dunes.
chops450
I purchased same amazon kit you both posted. I am trying to mount to the front top roll bar and those clamps don't seem to fit no matter what combination of rubber grommets I use. I will check again when I get home tonight.
105,436
They do work well. But to get the clamps to make a secure fit, they go on very tight and the rubber when putting it on will make it few like it’s too small. That’s what u want tho!
If your still having issues, post some pics as to how it looks so we can help
chops450
chops450
Are you running no rubbers on top roll bar? This is with the skinniest rubbers in. Maybe two threads in bottom bolt.
0429201933 HDR
105,436
There you go! There a bit of a bugger but you’ll be glad they go on tight when the machine is herky jerkying around on the trail.
Just get the bolts started a few threads at a time and turn the bolts a few revolutions each back and forth so there even to get a good tight fit
renosxs
renosxs
19
32
reno, nv
[/QUOTE]
I installed these and found the rubber fillers for 1.75 were too large. I took a dreamer and sanded the inner ridges down a bit to make them fit. I also used a clamp th get the two sides close enough to enable the screw threads. If the clamps fall off I’m sure they will need to collect my boday as they are very secure. Mounting on the top back pipe they do touch the roof so find the least amount of roofline to install. You can see that in the pictures.
B4BDC326 CB0B 476A 83D4 8CFF1AA64C10 44C30159 6AA9 4D41 ACE7 E32B49DDD49F 319EA54F EAE9 4FE5 A049 01A7626A4309 6470E1D1 3A75 42FA B1BE 976F859D20C6
Reactions: chops450
