P1000 Mud Riding Build 32in tires 34in tires
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
Nice looking ride I have the c-fab a-arms coming. Can’t wait to get them on! Why did you take the lift off will they not warranty it with it on there?
Most places aren't going to warranty with C-fabs lift on it.
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
Few pics that relate to post #8
Close up of the mirrors still loving the they work great.
IMG 3718 zpstlsacaxq
Few of my snorkel that show it a little better.
IMG 3717 zpsknptertd
IMG 3728 zpsxjkdw780
IMG 3726 zpsuyvq2ylx
This shows the snorkel but also how clean the setup is on my street legal kit All it is is the box that says XTC super clean. (look back at post 8)
IMG 3727 zpsspjknrek
How I did my blinkers
IMG 3719 zpsfgzx4p79
How I mounted the switch and the emergency flasher button below.
IMG 3721 zpsbocrzkkg
Really happy with how my horn turned out.
IMG 3722 zpsr5zhbbi7
It came with this when I got it they say it keeps you able to have a smother gas petal.
IMG 3724 zpspafxdfz0
New item my flag got this off ebay.
IMG 3729 zpsxtvxv2pt
Got me a 72x14 that way I can put my 09 IRS rancher on the front as you can see it has ramp to drive it up the sides.
IMG 3766 zpsyttf6sng
Just a funny.
IMG 3788 zpsiepnhlcf
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
Thought I would share a little info. (If my math is off let me know)
Diameter x Pi. So 32x3.14=100.48 for a circumference compared to 27x3.14= 84.78
84.78 divided by 100.48 is .8437 so about a 15.62% gear increase, x 1.25 for the IGR is 1.05%, portals 4in 30% with IGR is 1.55 for a net 30.77% gear reduction, portals 6in 45% with IGR is 1.70 for a net 43.42% gear reduction.
So being I'm just doing the IGR I'm almost back stock just a little better by 1%.
Rebelyell31
21
11
Florida
That’s good to know if I leave my gears stock and run a 30” v tread my tires and wheels will weight 50 lbs altogether do you think I will have any problems turning them? I’m waiting for Honda to get the parts to do my clutch recall. I’m the guy that just rides around I don’t going looking for mud holes I just like the look of the v treads and if I do have to go threw the mud I will get to the other side
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
I have 32s now with no IGR and have no problems 30s should be no problem but You are increasing the strain on your motor and transmission. Think of it like a bike with 5 gears and you are going up a hill the the less gear you have the harder the more the easier same for your SXS.
Rebelyell31
21
11
Florida
I got ya I should be fine then I just cruze most of the time and I always have low gear if I should need it thanks for the info I do some work in Hattiesburg from time to time at USA yeast thanks for the information
Reactions: Bradley-Thornton
Rebelyell31
21
11
Florida
Also one more question I see u did the high lifter bracket lift and the c-fab lift do u have any problem with the axles binding at all?
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
No, but C-fab sells a 2 1/2 you can stack now. I seen a guy say he had a problem come to find out he tighten bolts before letting the SXS down to let everything settle. After you put everything on you should let it down roll it back and forth maybe jump up and down on front and back then while down tighten it all up. I drove mine all over the yard but do as you feel comfortable.
Reactions: pct
Rebelyell31
21
11
Florida
Bradley
Did you have to grind the top rear a-arms so the rear shock would clear without hitting the a-arm? If so how much? Corey told me to grind some off but didn’t know how much thanks
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
Bradley
Mine didn't rub it was close like a 1/16in but it doesn't. I would say try without first but if you need to it will be very little.
PMiller0530
PMiller0530
Lake Charles, Louisiana
Man..., I love your bike! I will be lifting my bike soon when I get time. We are going back to Sabine campground May 5th and I would like to get my done before then. I have a 12 x 6.5 trailer and was wondering about lifting 32 inch tires with out them sticking out. My bike is a 2016 with 32 hours on it. I just work alot and hardly have anytime to ride. I might have about 2 inches on each side of trailor to play with. I am trying not to but another trailor, bc it is still new like bike. Appreciate the info you posted, very good stuff.
Rebelyell31
21
11
Florida
Thanks Bradley I ended up getting them on with out having to grind anything they sent me the wrong lug nuts so I’m getting the right ones tomorrow and will post pics once I get the tires on
Bradley-Thornton
Bradley-Thornton
684
1,650
Hattiesburg MS
I measured mine I don't have my spacers on it right now it was 64in just little info.
Also Thanks
Reactions: pct
boatman22
172
309
Woodlands TX
  3. Other Brand
Bradley, did you do the IGR?
Similar threads
Replies
Views
479
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
