P1000 My DIY Whips
Robobrainiac
Robobrainiac
2,464
8,600
haha my whips have no written or implied warranty. But for the cost of 1 pair of millar twisted 5v whips i can build 3 sets of mine and have some cash left over. so i'd have to break 6 whips before i was at any kind of a loss vs their lifetime warranty. I'm fine with that.
Also FYI the Millar controllers can almost control everyone else's whips :p the friend with the dream extreme whips learned he could change everyone's color and probably changed the color on about 50 machines at the Halloween ride. He thought it was hilarious.
Robobrainiac
Robobrainiac
2,464
8,600
Cool. Then I will wait for your findings before I start on my next whips. Until then I will try to improve what I currently have. Thank you!
I will hopefully get my hands on them in the next couple of weeks to do exactly that for myself. I'll pass along any information i can get. I agreed to take on some interesting builds over the weekend. It will be a couple of weeks but i'll be turning out a set just like these but with blacklight strips for a friends rzr with solid white plastics and a neon yellow/green power coated frame and bumpers. Should really make it pop at night.
Reactions: Biteme and Isaiah
SuperMidget
SuperMidget
100
362
AR
I know and that was part of why i searched out a different controller than they use. The 366 pattern controller i linked in the 1st post has an option to hold the bottom left button locking the controller to that remote only.
57,038
Almost finished wiring up my DIY whips. They look really good so far except for the base. If we could find a good base solution on the cheap I think these would look every bit as good as any of the pricier prebuilt options out there. I've been thinking of using quick disconnect air fittings, but that'll be for the next set. Taking my time wiring these guys up.
PXL 20201027 225438362
In researching all the LEDs and pieces and parts, I came across some nice prebuilt 3' pairs with RF and Bluetooth app control for a good deal. I'll be testing them out soon and hopefully be able to offer them for sale.
DIY on right, prebuilt on left.
PXL 20201028 023211084
SuperMidget
SuperMidget
100
362
AR
An air chuck is exactly what I was looking at the other day. Its as simple as finding a bolt with the right npt thread to screw it onto really. Those look good
Robobrainiac
Robobrainiac
2,464
8,600
I am remaking mine soon and these are the bases I have picked out for my next whip
https://amazon.com/Tram-CB-Antenna-217/dp/B08KWD2R3V?tag=sxsweb24-20
What did you use for the tip?
57,038
57,038
@SuperMidget - I finally got all my wires run and everything hooked up. Flipped the switch and only one whip lights up? Then as I was playing with the remote I noticed that the wires coming from the controller to the 12v power were so hot I couldn't touch it. Unplugged everything...
Does the controller need to be on the 5v side? I have it wired into the input side of the converter. After wiring in a new controller into the 5v side I got nothing. Checked and it's only putting out 1.85v on the 5v side. Guess I fried it? Thought I may have a short but everything was wired correctly and solid. Maybe I just got a dud converter? It gets super hot.
PXL 20201030 2034531552
Reactions: Biteme and JenElio
SuperMidget
SuperMidget
100
362
AR
Battery into 5v transformer, then transformer output out to controller.
Reactions: Biteme and Adam490
SuperMidget
SuperMidget
100
362
AR
Knocked out a blacklight set tonight for a friend. Should look pretty sweet once installed. Going on a rzr along with 8 blacklight rock lights.
20201030 190135 20201030 190138 20201030 190143 20201030 195431 HDR 20201030 185559 HDR 20201030 213553 123136215 3713675061975923 1098591505350246258 n107366706 3011931505569761 4852271202232580834 n
Robobrainiac
Robobrainiac
2,464
8,600
Reactions: Biteme
SuperMidget
SuperMidget
100
362
AR
Robobrainiac
Robobrainiac
2,464
8,600
Ws2812b led strips are 5v. Most controllers work in a range from 5v to 24v. But the led strip you use determines the voltage input required.
So I would still have to use the converter with the controller?
Reactions: Biteme
SuperMidget
SuperMidget
100
362
AR
I say it in my 1st post here. The whips i made i used WS2812B Eco LED Strips. They are 5v only strips that control each light individually.
there are many other types of LED strips available that are 12v and will work with the same controllers without the 5v step down transformer. WS2811 LED Strips control the lights in blocks of 3 and will do the same patterns on the same controller with 12 volt power.
SuperMidget
SuperMidget
100
362
AR
NOOOOOOOOOOOOOOOOOO I totally missed this link, DO NOT USE THAT QUICK RELEASE!!!
The external wings bend if any force gets applied to it... I left those vise grips holding it like that for 6 months before i just recently took it off and bolted my whip straight to the rack.
Try this one instead
20200516 155447
SuperMidget
SuperMidget
100
362
AR
I tried some different things with the blacklight whips i made last night
These caps fit 1/2 sch 40 pvc perfectly
I got this to test the larger sizes and learned that 30mm heat shrink wraps over the wiring nicely and seals up around the top cap/top of the clear heatshrink, and 20mm fits the bare pvc nicely to hide the white at the bottom better than painting it if you put it on first.
If using ip65 waterproof led strips this 35mm crazy thick heavy duty heat shrink did a pretty solid job
123009619 449904409311030 1187626273734176934 n 123047227 2800079613643637 5619410406010557964 n 122962388 1013321595746499 3374716898663590435 n 123137547 3713703248639771 5781265768297524421 n 123088656 3713703035306459 3160229100598387969 n 123074986 3713702945306468 2644378323816461671 n
Reactions: Adam490 and TripleB
