Talon My99svt's Talon
My Talon Build
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
my99svt submitted a new Garage Item:
My99svt's Talon
Just creating a thread for my Talon build. It won't be in a particular order. So far I've added:
hondasxs.com key-on accessory: KEY ON POWER Harness for Honda Pioneer 1000, 700, 500, and Talon 1000.
hondasxs.com seat belt bypass: Harness accessory seatbelt bypass kit - Honda Pioneer, Honda Talon
Rigid Red Chaser light: Chase
Switch Pro modular switch controller: SP-9100 Bezel Style 8-Switch Panel Power System with Concealed Mounting Hardware
Pro Armor harnesses: 4 Point 3 Harness with Sewn in Pads | Pro Armor
Honda accessory center storage bag: Center Storage Bag
I looked at the spod in the beginning, couldn’t justify the cost since my wife was a student and not working.
It’s about the footprint of a sheet of copy paper. Just too large.
Reactions: my99svt
Vondy
Vondy
1,612
10,733
Houston,OH
Loving the idea of the switch pro. I a little pricey at $550, but sure would be a clean and easy install. It says that it can't be used as a winch control, any idea why? I understand not running the winch power thru it, but curious as to why the controls can't. Would be great to be able to put a winch in and winch out momentary button on it.
Did you run new power wires back to the battery or just hook to what honda provided for the winch?
Reactions: sharp and my99svt
116,574
Same here.
I think link is messed up. I get the same error if I click on it. If I click on his name on left and then "garage page" it opens fine.
Good it’s not just me lol. I know I can be a bit forward and rub people the wrong way at times but I mean well :) haha maybe @Hondasxs can look into what’s going on with it. @Vondy ill try the way u did thanks.
my99svt
my99svt
1,267
5,248
Yes, it is expensive, but the labor I saved not wiring all the switches was worth it. And I had credit card points on amazon so I didn't have to come out of pocket as much.
I saw that about the winch, But I planned on installing a Warn Axon 5500, and will use what comes with it. I've had issues with the switches I've used for the winch on my pioneer.
I mounted the brain by the battery, comes with 2' power cable to connect to battery. See pic for brain location next to airbox.
rlltjcsmsey1ossonrtuca-jpg.120432
my99svt
my99svt
1,267
5,248
Congrats @my99svt! That is going to be an awesome machine!
Did you get the reverse light working yet?
Sort of, I couldn't find that connector so I wired a manual switch for now. I'll find that connector later and have 2 ways to turn it on.
Thanks again for your help!
Reactions: sharp
