Need advice on a tire
Teebow
Teebow
281
1,185
Kentucky
Just spotted this today while cleaning. Would you all replace or repair tire and is there a better fix if possible. It’s not leaking but I’m ocd about stuff.
BA3680DD C41D 4089 B02D 633B2B92E8DD
PaulF
PaulF
1,462
4,810
If you are damaging tires like that out riding, you may consider repairing it and then make it a spare. Then get a takeoff tire and wheel and replace it.
208,013
Or get better tires and forget it? Stock tires are terrible. Been there done that.
I don't know when I see her next time I see her if she needs a hug or I have to shoot her, you know I'm just being an ass on the latter, Id just run! I think I can out run her?
She’s going to vulcanize you.....😂
SP82
SP82
101
356
CA
I worked at a tire shop for five years (2 decades ago) rule always was if you can see the nylon (looks like you can on yours ) it’s no good. Not to say you couldn’t use it as a spare but I’ve seen a lot of sidewalls fail for less. Cost of a tire doesn’t seem worth it if your deep into a trail and get a flat. Even if your prepared with a jack and a spare it’s usually never convenient. Someone else stated above the stock bighorns aren’t the most durable. If it’s in the budget maybe upgrade to something stiffer.
Sent from my iPhone using Tapatalk Pro
HBarlow
HBarlow
1,618
6,010
Daniels, WV
Is your Talon insured? If so, what's the deductible?
The wheel & tire are damaged. Retail price on the tire and wheel is probably around $500 - $600 plus labor.
A Talon is capable of 75 mph and can easily cruise at 50 mph. If you drive it on public roads at speed I would replace the tire. If it's only driven off-road at low trail speeds in conditions that might cause similar damage again I would drive it as is. Most owners want to replace their tires (and wheels).
That tire and wheel would make a good spare.
105,610
Put an inner tube in it. I did that to a brand new tire of mine that got a side wall gash 3 years ago and I use it as a spare. Has been fantastic when i needed it and holds air great. The tube cost me 20$
Did the same but put a boot in the tire first...
bk5r
38
59
Congress, AZ
Did the same on my left front tire at about 600 miles. Took the tire off the wheel and put about a 2 X 2 patch on the inside. Glued the flap down and it held up fine until 3000 miles when I put on new tires.
Teebow
Teebow
281
1,185
Kentucky
I think that’s what I’m gonna do.thanks
Reactions: Rick53
