BigOL3
Seems that would leave the back narrower than the front????yes its close. I personally if you don't want a big difference but want stability do 1" Spacers on all 4
We are in the desert and personally that is what I have as a set up. A huge difference in handling it. but yes it is by 1/2" on each side. That is why we offer the ultra wide track bundle and the Extra wide track bundle depending on where you ride and your set up. Our wide track is the most popular 1" in front 1 1/2 "on the back the extra wide is the 1" front 2" on back.Seems that would leave the back narrower than the front????
30x10x14 Tusk warthogs.What make/model/size tires you running with wheels?
It is...if you want to keep your track width the same run 1in on rear alone.....or 1in in front and 2in on the rear.Seems that would leave the back narrower than the front????
Im sorry bud...i thought i had posted the 14x7. If you dont have any intention of going to 30s i would go with the 12s though.Guess I am confused ..... I thought you had the 12" beadlocks below you posted earlier. I was having problem finding many 28x12 is why I asked what you had ..... lol
STI HD Beadlock Matte Black ATV Wheel 12x7 4/137 - (5+2) [12HB127] - Single - Wheels - ATV
Yeah, I like that concept, the only problem being very limited true 28" tires.Im sorry bud...i thought i had posted the 14x7. If you dont have any intention of going to 30s i would go with the 12s though.
Berserkers!!Yeah, I like that concept, the only problem being very limited true 28" tires.
Well, the key is to make sure you firmly grasp the base of the shaft before you start shoving the bb’s down the hole. That insures you don’t shoot off in the wrong direction!Good info. I'm going to get the 28" evos on my stock 12" wheels. If i have any issue with the stock wheels, I'm gonna get the 12" beadlocks. I've been reading post for almost a year now and I like how u go from off the wall s***, to being a dick, to good solid helpful info. Lol
I like everything about them except the price. Will call them today to see if they go on sale anytime soon.Berserkers!!
Do those 15s make for a pretty rough ride? They all seem cheap enough, but wheels do not appear to be beadlocks.This is what I'm running.
Wheels.
https://amazon.com/gp/product/B017OF96G2/?tag=sxsweb24-20
These on rear.
https://amazon.com/gp/product/B07527CG52/?tag=sxsweb24-20
Tires.
https://amazon.com/gp/product/B07NGJRFBZ/?tag=sxsweb24-20
Thanks to @Average_Joe
Does the softball trick require only a SLIGHT indention of 1/2" or so? Will 'area' be only 1 softball big, or several softballs wide and tall? Does that have an adverse effect on weakening the wheel well plastic?The 30x10x14 Evos measure 28.5” at 10psi off the machine which will fit without arched arms. You can inflate them to the max pressure on the side of the tire and leave them there for about a week and they will be at 30” at @10psi. Gives you a choice.
But for 30’s you will need arched arms or the softball, with the softball you won’t need the steering stops like the arched arms.
1”F/2”R spacers are nice, at first I thought they were nothing but for looks but I have dual beadlocks and the front were rubbing on the arched arms under compression. So I bought a f/r set from members at 2018 Takeover it actually does make the machine more stable... It’s 69.5” wide vs 67.5 at its widest with just tires/wheels but far more stable.
Do you know of anyone that actually did that mod?No idea I put arched arm on mine, as long as you only get it warm enough to make it pliable it won’t hurt it but if you melt it it’s going to make it brittle there’s always that risk.
15" wheels with 28" tires make for a rough ride in my opinion - When I first started I had that set up and really did not know what I was missing until I went with 14" wheels and 30's.Do those 15s make for a pretty rough ride? They all seem cheap enough, but wheels do not appear to be beadlocks.
Let me know what you find. I currently have 15 inch rims with 28" tires. While it looks cool it is considerably rougher riding. I am going to use that set up around home but for trail rides I'm going to a 28" tire on 12" rims. Probably sti beadlocks. I'll most likely get berserkers for tires.I like everything about them except the price. Will call them today to see if they go on sale anytime soon.
