CATVOS 2.5” forward arms in the front
SATV rear
Tires are 32 inch Terrabites
1.5 inch wheel spacers in the front and 2 inch wheel spacers in the rear.
Front lift for CATVOS is advertised as 3 inches but only measures just under 2 inches. Shock angle is custom to prevent bind but allow max droop. Lower shock mount is moved toward ball joint.
rear lift is a custom lower shock mount welded in place. It retains the stock shock angle but requires limit straps.
Front spring rate is 225#
Rear spring rate is 275#
Front ground clearance is 16 3/4 on the driver side and 16 1/2 on the passenger side measure from the ground to the lower a arm bolt.
Rear ground clearance is 17 1/2 inches on both sides measured from the ground to the lower a arm bolt.
The angle in degrees of the axle shafts on all four corners at static are:
LF- 15°
RF-14°
LR-17°
RR-20°
The angle in degrees of the axle shafts with wheels off the ground are:
LF-25°
RF-23°
LR-26°
RR-34°
I don’t have the stock mounting locations in the front to measure shock length but I can measure the rear suspension as I still have the original mounting locations in place.
Both sides are 20 3/4 inches limited by a limit strap. No CV binding in the front or the rear.
Camber settings are a little bit difficult to measure accurately but judging by just looking at it it’s pretty much 0° on all four corners
