Vikes79
SKOL!
So for those that don’t know, my front drive shaft recently got hungry and ate up all my heater duct work and wiring.
It took out the seal on the sub trans and the shift cable boot. I have new parts of both.
According to the post above it sounds like I need to pull the front bumper?
Is there a different way to get the drive shaft out?
Is it possible to just move the front diff forward enough to remove the shaft?
TIA!
P1000 - Low gear gone
Mine wont stay in low, I'm guessing the gear dogs are worn. Starts out fine then bangs and goes into neutral. New shift cable and its properly adjusted. Sub trans fluid level fine. I've called the three closest dealers to me and none have heard of this problem. One says they are a week...
hondasxs.com
TIA!
