P1000 New battery
slick330
6
Buckatunna MS
I need a new battery for my pioneer. What is the best replacement battery for the stock battery? Im not running dual batteries as of yet but just need to know what fits in the stock slot for the primary battery.
Reactions: Lady01
115,786
There are quite a few so called brands out there but only a few company's that actually make batteries. Stay away from lithium. Just a standard acid battery will do. I buy Exide or Interstate. If u take the number iff your stock battery youll be able to find a Souter for replacement.
lomax
lomax
17
70
Denver Colorado
I have used Motobatt on several of my motorcycles and have had very good luck with them. I just dropped one in the spare battery slot this weekend just to be used as a jumper just in case. There is so much room in there i may actually put in a larger one.
Reactions: Lady01
Seadonist
Seadonist
380
1,117
New Orleans
Why do you suggest availing lithium batteries?
115,786
If u use a stnd battery as ur secondary with an isolator it dosnt play well with others. Some have had other issues with them in the honda when they discharge. They also dont like trickle/float chargers especially with a secondary battery set up. There are a few other issues i cant recall of people having them in the honda and other machines that wasn't good.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Get sealed acid battery make sure the terminals are on the correct side
Reactions: Remington
