Check out this new split windshield Honda just released. Top is fixed and the BOTTOM flips out! Quick and easy to transition from full protection to full air flow to STOP dust by busting the low pressure behind the window. Amazing!
How much? Im not seeing anything on it.Check out this new split windshield Honda just released. Top is fixed and the BOTTOM flips out! Quick and easy to transition from full protection to full air flow to STOP dust by busting the low pressure behind the window. Amazing!
View attachment 77160 View attachment 77161 View attachment 77162 View attachment 77163 View attachment 77164 View attachment 77165
This is definitely a home brew solution. Looks like he simply swapped upper and lower mounts?How much? Im not seeing anything on it.
Awesome, modification. When I sat in @Tigermark P500 and the windshield tilted out from the bottom I said I to him it would be nice if Honda had the 1000 windshield like that.... I always hated the split tilt out as by the end of the day I would be hunched over looking through the splitCheck out this new split windshield Honda just released. Top is fixed and the BOTTOM flips out! Quick and easy to transition from full protection to full air flow to STOP dust by busting the low pressure behind the window. Amazing!
Thank you Paul! Fabulous! I sure appreciate the reply and pics!Mike, I fabricated the center support from 1/4"x1" flat aluminium. Used a plastic handle off a small donor ball valve (pulled it off), and painted the bracket with wrinkle paint. The bracket has a slight bend and a 8mm hole and used a plastic knob on a 6m bolt to attach it to the center support on the dash. When the screen is down, the bolt and knob screw back in the same center hole on the lower windscreen to hold it secure.
This should'a been the way this windshield came from Honda...
If you need more or better photos, just let me know.
Paul
