New springs won’t settle
DDCole
9
41
Medford Oregon
  1. Talon X4
I was hoping someone might be able to give me some advice. I just replaced my stock springs on my 2020 1000X-4 Live Valve with MTS Dual Rate Springs and can’t get the shocks/springs to settle and they are super stiff. It’s almost like the ECU isn’t communicating correctly but there is no warning lights on. I did the two fronts at the same time and the rears. I called my local Honda shop to see if the could run a diagnostic on it to see if the shocks and ECU are communicating but they told me it’s a 6 week wait just to get them to hook it up.
Thanks in advance.
HondaTech
Have you tried the demo mode to see if the stiffness is different between the modes?
Have you driven it? Some codes for the LV system dont trigger unless the unit is driven above 19mph.
DDCole
9
41
Medford Oregon
  1. Talon X4
No I haven’t but I will. What kind of code could it be if it was fine before the spring swap?
