For me, I leave it in 1st and set the parking brake when transporting in the back of my pickup. As long as the hill isn't terribly steep, I would leave it neutral and set parking brake, sometimes running and sometimes not. For hunting, I wouldn't have a SXS without a parking brake. It's great!Why does the P500 not have a Park Gear?
When towing the P500 on a trailer should you use first gear and the park brake or Neutral and the park brake?
If parking on a hill is leaving the P500 in Neutral and setting the park brake enough?
P5 won't start..in gear..If I am not mistaken...Honda will tell you to just leave it in neutral and use parking brake...but most people it seems that I have seen, including myself, will usually leave it in 1st gear and apply brake. Although if you do this...some folks warn you to always put back in neutral before starting it back up!? Not sure about that one...I do it both ways depending if I think about it or not before I jump in and crank it up.
Park brake...Wether in gear or notIf parking on a hill, shift into the gear for the direction you do NOT want to roll. Leaving it in gear only saves it from rolling in one direction. So if you think it will roll backwards, leave it in reverse, if you think it will roll forward leave it in "L".
...keeps it from going...any direction
That's kool...I dont trust em
Carry a big rock...I dont trust em
Carry a big rock...
put behind..or in
...front.of tire...
caveman style
...hahaha
Kool pic..
lol yep. That is the narrowest part of the trail, which is just wider than the P500. Now that I have 1.5" spacers all around the pucker factor will likely increaseKool pic..
you roll off that
...your fish/ Bear bait
I have gotten into the habit of putting foot on brake when cranking anything without even thinking about it...so I have started it in 1st several times simply by applying and not realizing it until I go to put it in the gear it is already in!P5 won't start..in gear..
Applying foot on brake..p5
starts in any gear...
I tow mine...in neutral..
with park brake
Ride safe...brolol yep. That is the narrowest part of the trail, which is just wider than the P500. Now that I have 1.5" spacers all around the pucker factor will likely increase
with park brake
