P700 No Start , No Display
DAIII
DAIII
70
92
New Hampshire
Oddly seems like I'm posting more than ever-- and hope someone has some ideas-- heck you all fixed my leaky radiator hose.
Ok so it's cold out maybe 20 and the 700 is outside turn key on I noticed the display didn't illuminate and it won't start. If I leave the key on it seems to warm up the display then illuminates and then I hear the buss (assume its fuel injected) any ideas?
41,829
Check the battery connections. Don't recall what power relays it has, but try swapping them.
DAIII
DAIII
70
92
New Hampshire
Ok I added a battery booster and it started- lots of cranks.
Oddly before I did any of that - I was going on and off with key and it kept all the dummy lights on even with key off and out the cylinder. I disconnected the NEG side and it seems to have reset. working normal again.
Reactions: DG Rider
41,829
Hmmm...search this on the 500. Seems to happen a lot on them. Can't remember if its a relay thing or ignition switch. Sounds like a relay hanging...
Cold does weird things to electrics.
Unfortunately, The 700 is a notoriously finicky starter in cold weather. Stock battery isn't very strong. Seems like starting it for a few cranks, then turning the switch off an starting over again works best (AKA loading the engine with fuel a bit).
DAIII
DAIII
70
92
New Hampshire
ok that make sense. are the relays under the seat? for next time maybe I can warm them up?I let it run and now its in sun- Added Stabil with gas line anti freeze just in case it was hung up. I'll have parking for it next winter for sure.
Reactions: DG Rider
All the lights being stuck on with the key removed is the main relay sticking. For whatever reason, turning the key on and off repetitively will make it stick.
This could also explain your dead battery, it drained all the power out of it.
41,829
They're up under the hood...
