Noise in 2wd
AMink
AMink
251
1,883
Reno, NV
I tried searching but came up empty. In 2wd my Talon has a rattle/vibration/noise that seems to be coming from the front somewhere. In 4wd it goes away. Under throttle it keeps getting faster as speed increases. I checked u joints on both ends of the shaft feom the sub trans to the front diff. They felt tight and I put some JB Weld on them to keep them from backing out. I didn't have access to a welder. Looking for thoughts/suggestions from the pros.
AMink
AMink
251
1,883
Reno, NV
Nevermind, I found the threads that address what I'm hearing. When I get home and get the Talon cleaned up from my extended Labor Day weekend (stuck at a dry lake that isn't dry) I'll check everything again.
5,406
24,778
We'll be curious to hear what you find. The u-joint caps are definitely a known weak point.
mmuchow
mmuchow
7
34
Pittsburgh
The difference in noise/chatter between the oem driveshaft and SATV Driveshaft is noticeable, SATV is much quieter... I also inspected my oem driveshaft after removing it and it didn't have much play in the ujoints but there was some/enough to make the noise/chatter at higher speeds under load
