P1000 Not getting key on power
DewieCox
7
Illinois
Doing a KFI winch install and getting 0 voltage to the white-black tie in wire under the fuse block.
Curious if I may have overlooked a step or some kind of required add on.
Winch works wired direct to the battery and getting good readings at every point under the hood.
Reactions: TripleB
JenElio
JenElio
65,015
608,560
Loxahatchee, florida
U check the obvious? Like ground, make sure the fuse is good, the correct wire to tap into, etc? The club store has a nice (key-on power) plug-n-play kit
Reactions: TripleB
JenElio
JenElio
65,015
608,560
Ohhh 💡, im not trying to b a smart a** but, did u turn the ignition on?? 🤣 u never know 🤷‍♂️
Reactions: TripleB
TripleB
TripleB
11,932
101,069
Caryville, Tennessee
There is 2 different white and black wires. 1 is key on the other is not. I tapped the wrong 1 also. Find the other and u be good to go.
Reactions: JenElio
DewieCox
7
Illinois
LOL, let’s just say I’m the type of “mechanic” that will take the time to pull off some super complex pain in the ass thing and then overlook something dead simple, then decide to completely undo all the work that was done well.
Reactions: JenElio
DewieCox
7
Illinois
K, went out for a fresh look this morning. When I flip the fuse panel over, I can see where they go/come out of both sides. Should I be going after the pair that’s more easily accessible when I flip it toward the left/air filter or the right/battery?
Reactions: JenElio
TripleB
TripleB
11,932
101,069
I can't remember. I'm at work or I would look. If u tapped 1 and u aint got key on, then tap the other 1.
Reactions: JenElio
TripleB
TripleB
11,932
101,069
If u have a test light, u can figure it out pretty quick.
Reactions: JenElio
JenElio
JenElio
65,015
608,560
Im not in front of the machine either but they are both right next to each other. Like @TripleB. Mentioned, if it ain't one its the other. I believe the acc fuse is a 15 amp. If I remember correctly its about half way down the fuse box
Reactions: TripleB
DewieCox
7
Illinois
I’ve tapped both and I’m not getting voltage from either wire.
Not getting voltage when I put my multimeter up where they connect with the panel, though that’s just throwing stuff at the wall for my level of expertise.
Checked every fuse and all look good and replaced the 15a with a new one. Nothing.
TripleB
TripleB
11,932
101,069
Reactions: JenElio
TripleB
TripleB
11,932
101,069
Screenshot 20200714 124959 Chrome
According to this, there is 6 wires.
Reactions: Hondasxs
DewieCox
7
Illinois
And....
What was the problem?
I was going at the wrong wire on the wrong side. Flipped the fuse panel to the opposite side initially and there were two appropriately colored wires plain as day.
Should’ve been obvious which side to go after from the pics in the big thread and the most basic of electrical knowledge but sometimes just too smart for my own good.
Saved me probably $100 and I’ll at least entertain a future stereo install.
Reactions: TripleB
