P1000 OEM shock preload
ODAMO
ODAMO
1,286
3,461
Ohio
Is there any info out there on how much preload each step equalls on the KYB deluxe rear shocks?
Is the self levelling shock a better solution to manual adjustment?
ODAMO
ODAMO
1,286
3,461
Ohio
KYB deluxe shock??.........what yr P1K? The self leveling shocks have no adjustments
POIDH!!
The adjustable KYB shocks On The Deluxe.. . . .
2022
"Is the self levelling shock a better solution to manual adjustment?" Is a Second question
NO PICS Don't have one yet......
JenElio
JenElio
75,016
676,877
Loxahatchee, florida
2022
I can't speak to the '22 shocks as mine is a '19. I do have the self leveling rear shocks though. They have no adjustments what so ever, no pre-load, soft/hard settings. I would assume any adjustments if any would be better then none. I'm sure someone with whey more experience then I will chime in soon. Good luck 👍
ODAMO
ODAMO
1,286
3,461
Ohio
I'm curious as to which one is better adapted to repeated intermittent loads.
Reactions: Backwoods
JenElio
JenElio
75,016
676,877
🤔....my guess would probably be a better shock with adjustments. My stock rear shocks have never really been that great in my opinion. Yeah they will hold some weight, and while I've never bottomed out on the trail it leaves room for improvement. I think there's a video floating around of the inner workings of the rear leveling shocks system used on a P1K. Not sure which thread though.
115,818
It's not because I have no camera, It's because i have no Pioneer.
Workin to fix that. And the first, maybe second thing I will do is post a pic to prove it happened.
Just givin you sh!t cuz @JenElio aka Jennay asked you for pics. Kinda hard for someone not to have a Camera these days unless your from Reo Linda 😂 so that wasn't Why the Bartering was posted lol. It was quite obvious that you hadn’t got a machine yet 🥳
hope u get your machine soon tho so u can ride before summer is out! Would be a dam shame.
Also, can u confirm in some way that there is a KYB shock option Now? I know of the stockers (no pre load adjustment BTW on those) and the QS3 Fox upgrades.
  • Haha
Reactions: JenElio
ODAMO
ODAMO
1,286
3,461
Ohio
I saw KYB non adjustable rear on base model and KYB adjustable preload on Deluxe P3, P5 gets auto leveling shocks
JenElio
JenElio
75,016
676,877
Maybe Honda having a hard time sourcing Fox's so they switched to KYB's... 🤷‍♂️
Reactions: Remington
115,818
You mean P1K3 & P1K5 right, not P5?
So the P1K5 base gets the auto leveling. I had them on mine. There non adjustable and no preload. There not bad bit have a rougher ride for sure.
Reactions: trigger and JenElio
115,818
Thats quite a degrade imo. Sounds like there like an Elka stage 1 style. Id like to see the brochure that shows them
Reactions: JenElio
ODAMO
ODAMO
1,286
3,461
Ohio
Yes P1K3 & P1K5. The 3 gets adjustable, the 5 gets auto leveling
Base no adjustment
