P500 Oh Nuts! (With Spacers)
SuperATV
SuperATV
1,746
12,794
Madison, IN
www.superatv.com
No
No reply as of now.
I'll have to agree with the above statement. They're just cold. An unfortunate side effect of winter. 🤣🤣🤣
In all seriousness, I think you may have received nuts with a different chamfer from a different kit. That's what I'm looking into now. I'm getting the machine and order info so I can check out a box.
Idahotruckman
Idahotruckman
83
388
53
Boise, Idaho
What was SuperATV's response?
Thx...
I believe we can wrap this thread up soon.
Superatv has been good about communication and have provided good service. In a nut-shell, The lug nuts from Superatv that came with the wheel spacers were a little longer than the factory ones. The band of metal that circles the nut separating the head from the thread on the Satv is a smidgen wider. The taper angle appears to be the same, but the taper length is shorter on the factory nut. In the attached picture, the left nut is factory, and the longer one on the right is from Superatv.
I heard from Superatv today and they instructed me to install the shorter factory wheel nuts on to the spacers to secure the spacer on to the hub, and to then use their provided longer wheel lug nuts to secure the factory wheel on to the spacers.
I am still a little uncomfortable with threads still showing on the nuts holding on the spacers, but will re-install blue loctite on the wheel studs and hope for the best. The instructions do not indicate any suggestions as to wheel torque specs - waiting to hear from them on that. The manual indicates the wheel lug nuts should be torqued to 98 ft lbs.
Thank you to all of you that offered suggestions and help. You guys are top notch in my book, and I am happy I joined this forum. Thank you also to Superatv's response.
I did tell Superatv that if my wheels fall off I will let them know. In that event I will be more than a little grumpy. :mad:
210309 Left nut from Pioneer 500 right from superatv with spacers
195,141
Good deal, SuperATV has a reputation for excellent customer service so glad to hear that. Spacers are normally torqued the same as the wheel lugs.
NitroxDiver
NitroxDiver
488
918
Concord NC
I wouldn’t worry about the nut being a little longer than the stud as long as you have plenty of thread engagement. Think about it like an acorn nut or a lug nut that’s closed on the end, these nuts always have more thread than needed you just can’t see them.
SuperATV
SuperATV
1,746
12,794
Madison, IN
www.superatv.com
Yep, we just have long different shaped nuts.
Ok, no more nut jokes... 🤣
I guess we made them all pretty universal for all the different wheel spacer/adapter fitments from machine to machine. Makes it easier. They're all a little longer to work with all the studs, and threaded all the way through. I had to go check to see if for my self. Lol!
