William
So I did my yearly oil change this past weekend, and here are a couple things I wanted to get out there so people are aware. One... after finishing, mine had a leak at the engine oil filter housing. So I had to replace it with my spare. No visible damage to o-ring. So I will probably replace it and the dct o-ring every time now. 2... I swapped to 10w40 this time, and there is a big difference in thickness of the oil. So when I checked the oil level by the manual instructions, it took a couple of minutes longer for the oil to drain back down and register on the dip stick... With 10w30, at 2 minutes with the engine shut off, the oil was pretty much all settled... 40 weight took more like 4 minutes. At 10 minutes the level was up to the max fill line on the dip stick. I repeated the oil check procedure 5 or 6 times over the weekend to be sure. Whoever is responsible for the oil level having to be checked the way it is needs to be kicked in the coin purse...
