With my clutch issues Iv'e been changing mine every 200 hours, got 945 miles on it and had 4 oil changes and still can't get the reminder to reset. turn key on to find what you want to reset, turn key off press sel button, turn key to I, the wrench blinks twice and your back to where you started, no reset???????????????????Well on the atvs the service light has always come on at 600 miles. Even before the maintenance 1 or 2 option. So that indicated a oil change which is what the light should come on every 1200, the only maintenance the chart recommends at 600 is to check the net snaps/clips and clean thw spark arrester (which no one does, ever).
Since the oil change is recommended at 1200 the dash IMO, should light up at 1200. I'm not debating oil changes arent better for your units. For instance Honda says my Grom should get an oil change every 2400 miles. But there is no way in hell, I'm pulling 2400 miles on a single cylinder air cooled engine that sees mostly high revs all the time. I change it every 600, might be overkill but I want that thing to last me.
