P1000 Oil preassure light
Cacherivercat
Cacherivercat
6
10
Des arc Arkansas
Any of ya'll know what psi the oil preassure has to stay above to keep from setting off the light?
I'm just curious its running fine after the new oil pump. Google sucks and is not helpful on this question. Thanks for any information.
20200808 160800
Reactions: TripleB and Isaiah
Reactions: Isaiah
HondaTech
The oil pressure light could mean high, low, or oil pressure incorrectly reaching the wrong place at the wrong time.
What made you replace the oil pump?
Cacherivercat
Cacherivercat
6
10
Des arc Arkansas
The dealership I bought it from replaced the oil pump. They said after it got warm preassure would fluctuate just enough to trip the light. They tried the switch first and the light would still kick on and Honda told them to replace the pump. They told me that one of the surfaces on the pump had a grove in it like something got stuck in it and caused it to drop oil preassure
I do know that the only time the light would activate was after you would drive it for a ways and then let out of the throttle and it would kick on. Just sitting and idling would not trip it. I am just curious to what factory has the low preassure setting set to that trips the light. It's a brand new machine that had 16 miles on it when the light first came on. You could cut it off and restarted it and the light would stay out for a good while and come back on.
I do not like having to replace the oil pump on a brand new engine and am worried that it might have done internal damage to it but what do you do? That is why I am asking for the low preassure shut off point. I would feel a little better if it was set at let's say 10 psi and was dipping below that point. I would be alright with 5 psi and it dipped to 4 psi and caused a light. But if its set at 2 psi and dipped below that I would half to say that for sure that I am probably screwed! Thanks guys and/or gals!
Oh and another thing! I keep smelling antifreeze and I seem to be loosing it from the overflow since the dealership did the repair but I can not find leak anywhere. I guess I will check the oil in a bit and see if it is going in there. I hope not.
HondaTech
I'll send you a PM tomorrow with some info. Kind of hard to type alot on a phone and my laptop is at work.
Cacherivercat
Cacherivercat
6
10
Des arc Arkansas
Alright yall. I thought I would update on it. Its been good since I got it back from the shop the second time. Lol
It was just the 100 mile service the second time I checked the odometer today About midway through our Sunday ride and I had a little over 300 miles on it. Thank yall for the help! I did use a different dealership for the service though. I just wish partszilla would ship my roof and my hard cab back. Its been ordered for over a month. Lol
P
peoples16127
16127
That is good news, but what did the dealer fix to make the oil light stay off?
Similar threads
