P1000 Ordered a Warn 4500# winch, do I need to add a battery?
rlutech
rlutech
261
359
So I ordered a Warn 4500 pound ProVantage series winch for my P1000. Just wondering if it would be wise to add a second battery to accommodate the current loads that will be used by the winch?
Reactions: sharp and Jshell3
lrandy129
lrandy129
Curmudgeon
NELA
Check out the amp draw chart from Warn for the 4500. An additional (or single, but larger) battery will definitely help on extended pulls. Possibly long enough to start worrying about the winch duty cycle.
Wd
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
If you hook it up correctly and use it correctly it will work with one battery.
E
elkguide
3,377
7,964
Vermont
My P1000-3 is running a Warn ProVantage 4500 and though I have only used it to raise and lower my snow plow, it works just fine.
pmward
pmward
136
303
Galena, Missouri
I pulled my 1000-5D over a huge bolder with the Warn 4500 using only the stock battery. Having said that, I am adding a second battery tomorrow to be safe.
208,726
Man where these things will go in 2 drive, I can't imagine the need for a second battery for the winch, I have used my winch 0 times and yes I ride some gnarly stuff.
Jshell3
@rlutech I have Yausa dual battery. Installed at same time I put my Warn Vantage 4000-s in.
Also put isolator from QuadBoss. Total spend was like $200 battery and all.
Maybe not because of the winch, but the radio, amp, lights, bilge fan, switch panel.... etc.
You dig?
Reactions: sharp and GPR1500SC
rlutech
rlutech
261
359
I really only want a winch because I ride alone with my wife. I don't want to be stuck with a 1200 lb. machine in the middle of nowhere and not have any options. I generally try to avoid gnarly areas while riding alone, but want to be prepared. Have even come across trees across the trail and no way around it. Still not sure if I'm going to add a battery yet or not.
Reactions: Jshell3 and sharp
Bayouownbeer
Bayouownbeer
797
1,119
Chauvin LA
You can add it later if you just do minimal winching you will be ok.
Reactions: sharp
Boomboom907
596
620
Washington
Everywhere is different man. I still didn't find bottom. Took us 30 mins to get it out cause I didn't have a winch and my buddy had a 4 wheeler.
My clutches were fried by the time we were out.D6014d3c12340a24f02cf7738c353df5
Sent from my Pixel XL using Tapatalk
Boomboom907
596
620
Washington
These rigs are closer to 1800 lbs
Reactions: Eltobgi
208,726
My clutches were fried by the time we were out.View attachment 46198
Send a truck down and we'll load it with rocks to fill lichen fields, HA!
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Yeah buddy! That's a good stick there.
DMH
DMH
354
284
Central Florida
Come on down to Florida and dip your toe's in the cool wet sand. :)
First stuck. Made it through on the way out but coming back in it got us. Good times!
