P1000 Overhead stereo
O2bsmitty
O2bsmitty
298
659
Illinois
Can someone give me the inside measurements of the roll cage on a p1k5? Needing side to side and front to back on front section and back sections of cage. I haven't picked up my pioneer yet and have some free time and could get started on the stereo build. Also how much room is between the Honda hard top and top of cage? Thanks in advance.
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
I would but I'm at work right now if somebody else doesn't before I get home I'll measure it
O2bsmitty
O2bsmitty
298
659
Illinois
Thanks. I probably should wait til it's home but it's hard with free time and would like to have it done so I can mount it soon as it gets home. Lol
BWAF
BWAF
8,864
42,478
Carthage MO
You can make the box and leave the brackets a little long and trim them down to get it to fit good .
Reactions: CumminsPusher
O2bsmitty
O2bsmitty
298
659
Illinois
This is mine for idea's
Nice. My idea is similar but doing boss reciever, 6 - 6.5" boss 3 way speakers, a boss amp and 2 - 8" subs. Thinking stereo and switch panel pretty much like yours, 2 6.5's front corners angled back at front seats and middle, 2 6.5's in corners above front seat angled forward and middle, the 2 8's in middle behind roll bar either straight down or angled into one another, 2 6.5's in back corners angled forward and middle with amp mounted in middle of back section.with color partially hidden color changing lights worked in somehow around perimeter. Might do 8's more toward outside and leave room for something else in middle. Maybe 10" or 12"?? This is what's in my head right now anyway. Subject to change who knows how many times. Lol
Reactions: BWAF
O2bsmitty
O2bsmitty
298
659
Illinois
I thought about that but I think I want the gap between the box and bars to be minimal hopefully look more "factory" than something added. Idk.
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Post picks when you get it done would like to see.
Reactions: O2bsmitty
BWAF
BWAF
8,864
42,478
Carthage MO
how did you mount the console to the roll bar
You can kind of see it in this pic I made like a clamp bracket front and rear Bac6edaefe9c0f95576ca51e0c9e657b
BWAF
BWAF
8,864
42,478
Carthage MO
Cage to hard roof on middle bar 1.5" can't get any other good measurements because my speaker boxes are in the way :(
O2bsmitty
O2bsmitty
298
659
Illinois
How about inside measurements of bars from side to side and front to middle and middle to back?
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
Side to side I can't get because of my speaker box I'll try to do front to back in the morning
O2bsmitty
O2bsmitty
298
659
Illinois
This is front section base coated and equipment. Got to do some "smoothing" to do to it and figure out leds. Should get back section Built today 2 6.5's and 2 8's are going in it. How did you run your wires from battery. I'm going to mount my second battery under the seat, is there any way to run it inside the middle cage post? Don't really want wires exposed.
IMG 1284
IMG 1285
IMG 1286
IMG 1287
Reactions: BWAF
BWAF
BWAF
8,864
42,478
Carthage MO
This is front section base coated and equipment. Got to do some "smoothing" to do to it and figure out leds. Should get back section Built today 2 6.5's and 2 8's are going in it. How did you run your wires from battery. I'm going to mount my second battery under the seat, is there any way to run it inside the middle cage post? Don't really want wires exposed. View attachment 71275View attachment 71276View attachment 71277View attachment 71278
Looking good Honda is home need any measurements
O2bsmitty
O2bsmitty
298
659
Illinois
What does it measure from mid cross bar to back cross bar?
O2bsmitty
O2bsmitty
298
659
Illinois
I revamped the front section today and got the back section built if it's the right size. Now just waiting on the components.
BWAF
BWAF
8,864
42,478
Carthage MO
Mine is a 16' don't know if that matters
