P1000 Oversize switch blank removal
Merv
VIRGINIA
Yikes, any tips / suggestions on removing the OEM oversize switch blank on a 2022 Honda Pioneer 1000-5? I’ve removed the safety label and cut a rectangle out for hand access, but I just can’t curl my hand & wrist enough to feel for and grab the pinch points. Are there two pinch points, one each on top and bottom? Thanks.
5,030
22,478
If it's the same one as on a Talon, I had to carefully pry it out from the front. Yes, there are two tabs (top and bottom) but they were so stiff I couldn't pinch them in enough to release the blank (limited access didn't help). I was able to pry it out from the front without doing any damage to the plastic dash.
1674869556329
5,030
22,478
Wow, nice job. Yeah, I think I “felt” the top tab, but couldn’t get any real leverage on it.
I didn't make the switch insert, I bought it from the club store.
Reactions: NewHere2
NewHere2
NewHere2
Village Idiot In Training
35,720
303,846
High Plains of SD
Use the search button in the upper right, search "Oversize blank switch" or
Reactions: Smitty335 and CID
NewHere2
NewHere2
35,720
303,846
High Plains of SD
Thanks for sharing. It’s always nice to know how it worked out.
Reactions: CID
Merv
VIRGINIA
I drilled a center starting hole and ran the multi-tool to each top corner. A lot of thick, unnecessary plastic in those blanks. I was done trying to pinch those thick tabs from behind…
Reactions: NewHere2 and CID
GovtMule
GovtMule
NTC’s SoA, Chief Sarcasm Officer-Self Appointed
11,901
115,408
Tennessee
I can’t remember exactly how I did it, but mine came right out. Used my dremel and put my winch remote in it and popped it right back in. Got to it from under the hood I do believe.
OR: Looking at my pic there’s small tool marks on the bottom. I could have used a small screwdriver there and pried it right out.
4C127DF2 76BF 4F86 949C 9AF542960249
