I hear alot of people talk about this torque management but I'm not sure what exactly it is or does ...
Or..
Someone needs to send their Pioneer ecu off to be programmed and report back.
After you invest in a PC with Autotune you will come out cheaper.
This weekend we were testing the power commander with talon ecu. At some point it messed up and we had to remove it. Out on the trail we really dont know what messed up but it quit working and installing the Pioneer ecu got us mo ing again.
With all the information you've helped me with. I believe I have come to the decision I'm going to get the power comander and AT cam and springs... unless you were talking about the talon ecu removing some torque management then I'll get the talon ecu I'm not exactly sure which one you were referring to lol
Talon ECU REQUIRES the PCV W/Autotune
You can do the AT cam but it takes a mod to the chain and gear as well. It’s not just swapping the cam. Another member did it and it added 26% fuel with an aftermarket exhaust, it looses bottom end with the AT cam, you’ll need an IGR and some electronic widgets that make the speed sensors read what the ECU expects and to modify the shift solenoid for it to shift right.
I would just do the Talon ECU and Autotune, carry the stock ECU with you. It’s a big enough increase in useable/available power that it’s worth it. The AT cam opens a can of worms that you have to fix.
The cam seemed like an easier thing but I'll take your word for it. And the ecu isnt expensive either ill just try to get all that probably around January. I'm also curious if the talon cam would be easier and what it would do for the p1k I haven't even googled that yet. Dude thanks again for your help and to everyone else on this site who have the money and balls to hack into these machines to test this stuff. I get nervous with buying expensive parts just to test if it would work lol but thanks again brother I appreciate the help.
Talon cam is more aggressive than the AT cam and Ive been told you'd need the Talon injectors on top of all the stuff for the AT cam swap.
Cam gears are ok with that swap or no?
I'll just leave the cam aloneYes you have to swap the gear and chain to swap cam. Its an undertaking, and because of the loss of the low end power you have to do the IGR which then makes you mod the shift solenoid and add $200 in electronics to get the trans to shift right.
Theres machining of the case for the IGR and the Cam gear and chain to fit as well.
So I’m not sold on the talon ECU just yet... still need to do some tweaking and figure a few things out. The power commander and auto tune I liked by themselves. But I would suggest folks holding off on the ecu until we get a few things figured out.
Or..
