P1000 P1k and talon ecu swap
O
Okie1987
Tennessee
Im new here and ive been following along on this the best I can. Im interested in doing a talon throttle body and ecu. Can you buy just a throttle body and swap over your sensors? Or do you have to buy a throttle body assembly?
GPR1500SC
GPR1500SC
861
2,427
North East MO
  2. Talon X LV
You could buy the throttle body by its self but I would buy the assembly as you need the fuel injectors, they are bigger on the Talon at that point the assembly is not that much higher and you got the new idle control motor and throttle position sensor.
Reactions: JTW
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Doing the throttle body without a cam swap might hurt more than it helps. You'll probably loose some bottom end and not turn enough rpm making power to benefit. You also have to reflash or have a Powercommander & autotune to get the fueling correct for the talon ecu.
Reactions: Adam490 and JTW
