Really?? Mine was square in the middle.Yes the hole in mine is offset to the passenger side
@Bubbadoyle you better check your peddle.
Yeah.. my bracket is angled up. But I put my hole in the center and it’s square with the contact shaft. With that pad I used it I could have been off a 1/4” and it still be fineAs I recall yours is higher up the pedal too.
It doesn’t have to be exactly perfect.. but you’ll figure it out. Your open closed shaft depth is the biggest thing to watch.Yeah. I’ll measure before doing it.
What lever did you order?Just ordered the lever. Won’t take me long to make it T at work with very minimal material so if I screw it up then no big deal. I’ll just do it again. Looks simple enough.
I am wondering if something like a golf kart pak break would workCan anyone explain how the parking brake works on the P1K? Has anyone parked on a steep hill yet and had to leave it in park? Did the tranny bind up when you tried to take it back out of park? I've been hesitant to park mine on a steep hill...
No matter the meticulous design and careful planning the manufacturer dedicated to it's products, a good percentage of people are not content to use it as designed.So is anyone using this? Honda Pioneer 1000 Parking / Hill Brake | Hillbilly Brake
Is it worth the cost/trouble? I've got to believe that Honda engineers knew what they were doing and forsaw that people would be stopping on an incline at some point and didn't think not having an e-brake was a big deal.
No experience with the hillbilly brake. Guess I'm just a tightwad but I prefer my 11.00 solution (I actually got 2 for that 11.00). Just my .02So is anyone using this? Honda Pioneer 1000 Parking / Hill Brake | Hillbilly Brake
Hillbilly Brake is awesomeSo is anyone using this? Honda Pioneer 1000 Parking / Hill Brake | Hillbilly Brake
I have the hill billy brake. With the addition of mud and corrosion the spring works poorly so it doesn't pop to unlock and sometimes you need to beat on it a bit to let it slide to lock. Overall it's a neat idea but not a perfect executionSo is anyone using this? Honda Pioneer 1000 Parking / Hill Brake | Hillbilly Brake
Mine works perfectly, only had it since the 21 TO, I will keep it lubricated, Thanks for the heads up!I have the hill billy brake. With the addition of mud and corrosion the spring works poorly so it doesn't pop to unlock and sometimes you need to beat on it a bit to let it slide to lock. Overall it's a neat idea but not a perfect execution
