Picked up a new toy
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
Not until I get it off the trailer
You need to find You a good tool maker buddy that lives close ,,, I have a good Friend that worked in a machine shop for 40 years, He has his own shop at his home also, He would work in the machine shop all day and go home and do it as a hobby and He has been a Very Valuable source of information and help, to have a Knowledgeable friend to help is Priceless,,,,
I’ve got several of those.. out vocational school teaches machine shop and that’s one of the biggest around industries here
Just what I need to make slotted channel brackets for my dump bed mount. Enjoy that beast of a machine!
Exactly.. I could have probably gotten by with less expensive wore out machine for what I’ll mostly do. But I’m 34... in 20-30 years who knows what I’ll be into.
Mudder
Mudder
NTC Ambassador of Walls
11,301
83,894
More than once I bought a tool and after one use said “Wish I had this sooner”. And then you find out all the extra things to use it for that you didn’t realize. Buy quality stuff and smile forever.
5FFD81A7 59C8 432A AF81 59DEE566A97D
5DB91E89 4E33 436D B481 FDD2710A4856
EFFE297D 40BE 4D31 A6E9 D5BCF4E3B3BA
My shop is a f***ing mess!! I’ve got to clean that f***er up! But I managed to clear a hole for the mill. Got it unloaded and the vfd hooked up and went to turn it on. And nothing... I called the guy and apparently I need to run a couple more wires for the switch. I kept getting this error code
180B6CCA 77B0 4B76 B917 57FC0905302A
Mudder
Mudder
11,301
83,894
Curious how much it weighs? Looking forward to your first project.
Mudder
Mudder
11,301
83,894
@JTW , would a drill press handle a milling bit? 1/2 inch jaw, 450-2400 rpm.
06AD94A8 9DA8 4FC6 B98A D1D1644CC744
Buggyman
Buggyman
33,645
288,975
ne. ohio
maybe if you were just plunging straight down into a hole or something , but I would not try cross feeding with it as the spindle in a drill press isn't as heavy as a spindle on a milling machine just my 2 cent's worth. 41 years in tool n die shop.
Reactions: Mudwing and JTW
Mudder
Mudder
11,301
83,894
Thanks, was asking for cutting 6 inch slots in smaller gauge channel on the left of picture. Good to have some diverse expertise here.
FC2EBB78 BBE8 4404 96E9 9C6DA472FBA8
Reactions: Mudwing and JenElio
Buggyman
Buggyman
33,645
288,975
ne. ohio
if the matl. is thin and you drill a starter hole feed slow and easy you could probably get away with it . raise the drill table up and keep the quill engaged as much as possible to minimize flex.
Buggyman
Buggyman
33,645
288,975
ne. ohio
As they said.. it’s not the best idea. And why I went with a mill vs a press.
I have seen a lot of stuff in drill presses and mills turn into helicopters and go flying across the shop sometimes with body parts as well ( just be carefull and go easy ) hate seeing anyone hurt.
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
@JTW thought You may like this, I have watched this Gentlemen for a long time He is a pretty good educator on machine shop tooling and such,,,
