P1000 Pioneer 1000 Terra45 Winch Install.
63,990
@Calvin,
For the light on the switch. I just ran the brown wire tap straight to the switches via the yellow wires shown behind the switches.
NO. Do not run this USB via the brown wire light tap.
The light will always be on whenever it has power. Don't really need a relay. But I would fuse it.
Calvin
Calvin
42
Benton, La.
@Calvin,
Ok thx for info. Great write up and informative.
Reactions: Hondasxs
63,990
Your ground buss? I'm trying to get a good look at what you did there?
Here is the ground bus.
891d8dcd5f5fc9d5071e04cdb24920b1
63,990
@Johnny_C
Just make sure it is out of the way of everything. It is a un-fused positive you dont want touching anything.
Johnny_C
Johnny_C
303
143
Western N. Carolina
I'll contact Super winch to see if
they will send one to me.
Is it a thermal overload switch?
Thanks!
John
@Johnny_C
Kenjones21
Kenjones21
164
103
Central Louisiana
Questions?
What did I leave out?
Do you know what size wire that is for the key on power , I'm at work and was fixing to order the posi wire tap and wanted to make sure i got right size? I was thinking the 18ga to 22ga posi tap would work ?
Kenjones21
Kenjones21
164
103
Central Louisiana
Questions?
Calvin
Calvin
42
Benton, La.
@Hondasxs told me to get these this is what he used. He guessed it to be 16g wire.
63,990
@Calvin. Went back and looked this morning. I used the red ones with gray ends. They fit well. Not sure the size of them. They were included in the PDM kit.
Johnny_C
Johnny_C
303
143
Western N. Carolina
This was easy.
Mike replied
Dec 30, 8:55am
Hi John, I have entered an order to send you the missing part at N/C
Best Regards,
Mike Huth
Superwinch Customer Service Specialist
Dayville, CT | Portland, OR | Tavistock, UK
Office: 800-323-2031
[email protected]
Dec 29, 10:34pm
Contact Form Submission:
Email: XXXXXX@XXXX.net
Body: Hello,
I ordered a Terra 45 from Amazon,
Superwinch 1145230 Terra 45 4500lbs/2046kg single line pull with hawse, handlebar mnt toggle, handheld remote, and synthetic rope
Sold by: Amazon.com LLC
$252.42.
I did not get a breaker cover with my winch.
Can you send me one?
My address is 33 Blah Blah Blah
Blahville, NC 33333
Thanks!
John
Yes. I didn't get #13 in my kit.
John
Reactions: Hondasxs
AlpineRider
AlpineRider
OKC
Thanks Honda for uploading the picture of the Terra installation. I have a Terra 45 that I'm about to install. I had a Terra 35 on each of the quads I had before the Pioneer and was always impressed with them.
Reactions: pct
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
What is the purpose of the power distribution module? I've installed couple winches on atvs but I've never ran into one of these. What are the advantages? Also I keep hearing about the line angle concern from using a kfi mount. Are there other mounts that don't create this angle? Thanks for any help. After that mudhole I ran into yesterday, I'm ready to pull trigger on a winch.
Bonehead69
Bonehead69
73
44
This was easy.
Mike replied
Dec 30, 8:55am
Best Regards,
Mike Huth
[email protected]
Dec 29, 10:34pm
Body: Hello,
$252.42.
Blahville, NC 33333
Thanks!
John
Where exactly is My address is 33 Blah Blah Blah Blahville, NC 33333. Google maps has got nothing? LOL!!
Reactions: JTW
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
the cooper busman pdm that jackal and others have used on their builds has 5 fused relays and 10 fuses in one convenient package. it makes life simpler for adding multiple accessories because your relays and fuses are already to go in a plug and play module. a single heavy gage wire from your battery to the pdm powers all the relayed and fused accessories that you add to your vehicle (instead of having to wire them all up separately and potentially run individual power wires to each relay). it's not necessarily required for mounting the winch. It's just a convenient way to buy/install a new power center similar to your stock fuseblock and relay system.
as far as the cable angle, I believe all mounts end up with the same angle.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Cool thanks for the explanation. Not sure what (if any) extra electrical accessories I will add, so I'll have to think about buying one. As for the winch, is it too low or too high for the fairlead? If it's too low, is there enough overhead space to use a spacer block between winch and mount? I made one for my Foreman when new winch I bought sat lower than previous one.
