Pioneer 500 - Factory Wheels and Tires!
danmac
12
7
B2t1k4
Thanks buddy appreciate it and will post pics as soon as I get them
I actually thought about it last night not sure if I really trust the spacers as I have my little guy with me most times so might just bite the bullet on some 5+2 rims will that work as well, I been on quads my whole life never delt with spacers and offset rims just put bigger tires on never had a problem.i would go with 27 but I don't won't to cut the frame on a brand new machine I just want to get it right the first time is all lol I do appreciate all the patience thanks again for all the advice
Reactions: trigger and Mudder
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,390
Do you feel that your getting the same amount of speed with your tire set-up compare to stock wheels and tires.
Max speed showing with low psi is 39 mph. Ride much smoother, extra inch of ground clearance.
Reactions: Rustneversleeps
195,164
5+2 will give you about 52" and will be stable unless you start adding a bunch of weight up high.
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Sorry for the late reply.So if a went with 4+3 wheels would it make it 54'' wide without spacers...and if i went from 25-8-12 to 27-9-12 would it make 56" Approx...
195,164
All are approximate measurements, mine varies on any given day with temperature and psi. But yes, those should be pretty close. I have 26x11's on all four with 5+2's. With 1" spacers on the rear I'm at about 56" front and back.
Reactions: Mudder
