P500 Pioneer 500 ignition
Mudder
Mudder
NTC Ambassador of Walls
11,300
83,879
Find a fix yet @Sanders711 ?
clancy3rz
I turn the key to run position on my pioneer 500 and the lights in the dash doesn’t come on. But when I turn it between off and run the lights come on any thoughts?
Agree with rocmar. Had same issue with mine. Battery connections were slightly loose, which in turn allowed corrosion to form on terminals that was not visible until connections broken completely apart. Polished both battery terminals and cable eyelets with emory cloth until all metal was bright. Added a little dielectric grease and snugged fittings firmly. Year plus later and no reoccurrence!
SimonA
7
17
New Zealand
I've experienced just this problem (SXS500) over the last couple of days - turn key to first position, full display as usual, fuel pump starts up, check lights working, yes - on, then off - then attempt to start .... click from somewhere around the battery (?), screen goes completely blank, lights won't come on; everything dead. Disconnect battery (earth lead), wait ten minutes, reconnect, all looking good, screen working etc., but exactly the same result. Eventually followed the advice above and connected a backup battery to the existing battery and, voila, everything burst into life. So I popped into town and bought a brand new equivalent, optimistically screwed both terminals on tight, re-installed the cover, and away she went, and has been absolutely fine since ...... I've never seen a battery fail in this way (and my meter shows 12.65 volts even now). Battery was a Yasuda made in USA, but the original I think (2016), and clearly had developed some internal fault (?). So no problem with the machine itself, which, apart from a starter motor replacement (thanks to this forum for installation guidance), has been faultless. Bought secondhand at auction, sight unseen; foolish perhaps, but relatively inexpensive!
Mudder
Mudder
11,300
83,879
May be a coincidence but I just had a failure of my P500 Yuasa battery after one year. Used a Cteck smart charger to maintain it and my other powersports/tractor/zero turn batteries which are all ok. Always showed good voltage on dash voltmeter but failed load test and charging attempts.
208,011
Sounds like you have a drain either way?
SimonA
7
17
New Zealand
Thanks Mudder. Of course it was a Yuasa that failed .... not sure where I got Yasuda from! Only 1 extra letter ....
And Smitty135 - is there a way to test for a drain? I'm not sure there is a drain present ... the replacement battery has behaved well so far (only a week though), and the old battery had performed perfectly until that day, but I guess something may have "happened" to create a short of some kind, possibly through the ignition switch?
My view though is that, because the old battery would come back to life after reconnection, but failed under load, it was time for replacement .... time will tell. Meanwhile, it does need to start every day (no doubt true for all of us), and, at the moment, that's the result.
