YesIs it in Neutral for starting?
No sirYes , your turning the headlight switch instead of the ignition switch .
Yes it goes black as soon as you turn it to the run positiondoes it go black when you hit the start position or just the on position?
I'm still a little unclear as what you describe as the "Run" position. If this is when you turn the key all the way to what I describe as the "Start" position and it blacks out it could be a low battery. Your battery my have adequate power to light up the display but when the starter tries to engage it kills the power. This could be caused by a bad battery connection or a bad or dead battery.Yes it goes black as soon as you turn it to the run position
Idk what’s it’s called its when you turn the key over one click an the fuel pump kicks on.I'm still a little unclear as what you describe as the "Run" position. If this is when you turn the key all the way to what I describe as the "Start" position and it blacks out it could be a low battery. Your battery my have adequate power to light up the display but when the starter tries to engage it kills the power. This could be caused by a bad battery connection or a bad or dead battery.
Okay so you turn it to the On or Run position and the screen is black, does the fuel pump still run? Then if you turn it back a little towards the Off position it comes on. If this is correct it sounds like the switch is failing. Not sure of a good way to test it.Idk what’s it’s called its when you turn the key over one click an the fuel pump kicks on.
What happens when you try to start it?Yes it goes black as soon as you turn it to the run position
Fuel pump does not run but you can turn the key between the on and off position and the lights come on and so does the fuel pump. But if you try to switch it back to the on position is goes black againOkay so you turn it to the On or Run position and the screen is black, does the fuel pump still run? Then if you turn it back a little towards the Off position it comes on. If this is correct it sounds like the switch is failing. Not sure of a good way to test it.
It doesn’t do anythingWhat happens when you try to start it?
I'm still thinking bad switch. How olds the machine? Is it still under warranty?Fuel pump does not run but you can turn the key between the on and off position and the lights come on and so does the fuel pump. But if you try to switch it back to the on position is goes black again
I bought the extra 4 year warranty i just wasn’t sure if that would be covered under itI'm still thinking bad switch. How olds the machine? Is it still under warranty?
I don't know about extended warranty but I would definitely give them a call. If the warranty is just power train it probably not but if it's full machine then it should be covered.I bought the extra 4 year warranty i just wasn’t sure if that would be covered under it
Bad battery...loose connections..Fuel pump does not run but you can turn the key between the on and off position and the lights come on and so does the fuel pump. But if you try to switch it back to the on position is goes black again
