alloutdoors
I have a 6.5 x 12, and it works well, but if budget permits, then I would go aluminum, lighter weight so moving around the yard easier and you don't need to worry about replacing deck boards.....
I like my trailer!I have a 6.5 x 12, and it works well, but if budget permits, then I would go aluminum, lighter weight so moving around the yard easier and you don't need to worry about replacing deck boards.....
I used to have a trailer like this one, but the wire mesh as the bed kept getting low and lower till the dent was braking.If it's a 5'x8' with a tall ramp ,the fenders will hit the ramp.a little modification will make it work though.sold mine and just bought a 5'x10'.View attachment 63492
Welcome to the Forum!
Welcome from central Mississisippi to the forum, and I wish I could afford an aluminium trailer my self.
I bought a Summit 10' x 6' with the raised sides for $1800. I needed a utility trailer to haul yard waste, building supplies, my pontoon boats, and the Pioneer.
It has a really ingenious design in that the back gate turns into the ramps without having that huge fold up ramp that adds a ton of air resistance.
This is a week after I bought it...
But, since I can't leave well enough alone...
I added tie-downs in the bed, stained the bed with a darker stain, added a ladder rack to the front, then flipped the axle and added 29" tall Goodyear Wrangler AT tires so I would feel better taking it off-road...
I like it. Love the gate to ramps.I bought a Summit 10' x 6' with the raised sides for $1800. I needed a utility trailer to haul yard waste, building supplies, my pontoon boats, and the Pioneer.
I have a single axle 6 x 12 Lark trailer with a 6” taller roof - Inside dimensions are 11'-4" L (13'-2" to V-nose) x 5'-8" W x 6'-6" H - Door opening is 63in W x 72-1/2in H.
My 2017 fits fine, open trailer side access door, fold in side mirrors, drive in forward, set brake, exit through passenger side and side access door of trailer..Tie down on 4 corners and your done.
I also like the “Out of sight, out of mind” concept when towing the P500, especially if you stop somewhere for the night.
View attachment 240524View attachment 240525View attachment 240526
