P1000 PK5 power steering
Might try having the dealer initialize the EPS. Kinda like the guys that reported different assist levels left vs right and a little "pulling" one way of the other. It might be a little off and allowing the unit to apply full power up against the stop. That would get 'er to heat up quick!
Best idea posted yet
Hawkeye
Hawkeye
79
120
Illinois
There's been a few that have posted a couple of good suggestions.
1. Batteries topped off. Trickle charger, but if he uses each day probably not the issue.
2. EPS motor connection. If your a water rider or high pressure washer user may have resistance in connection. Resistance(ohms) across the electric motor is probably what is used to kick out EPS and not a thermal switch. Pull it apart use air to blow it out check for corrosion apply a bit of dielectric grease. This maybe your problem, I'd check this and once this is done and still not fixed it points to 3.
3. EPS out of specs. Excessive resistance in motor circuit kicking out EPS. Fix = replacement.
Get her fixed and good luck
Hawkeye
Reactions: JTW and knuckledeep
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
I’ve had mine act like it couldn’t keep up with the steering movement and the assist was lagging until I slowed the steering wheel movement.
Reactions: knuckledeep
L
Longshot
11
17
Northern WI
Full turn like holding it on the locks?
+1
Since there is no pump if it doesn't cut the power at the stops it just deadheads the motor which will build heat incredibly fast. Maybe Honda thought with the thermal sensor built in it doesn't need stop cutouts, probably cheaper to build that way. JMO
Reactions: knuckledeep and JTW
Deanb
Stonyplain
So Dad has had an issue with his PK5.. when he’s driving slow and at full turn going around a tree or thru a ditch. He will loose power steering going back the other way. He took his in to the dealer this week for a couple issues and a final service before warranty is out and the mechanic told him that the power steering was normal and was a safety feature to keep the pump from burning out???? So before I call bulls***, I figured I should ask you all.
@Hondasxs @lee @JACKAL @CumminsPusher @Neohio @joeymt33 @knuckledeep @HondaTech
Is there another dealer around. Does not sound right
Duke4nick
6
Pheba ms
I have owned Honda's since 1979 and never had an issue. I bought a pioneer 700-4 last year. I will say this. They are junk. From here on it will be a Polaris. Honda should have stayed out of the sxs business. That's my two cents.
Do they get in your way or cause you much problem???? Because I think your nuts are loose!
Mudwing
Mudwing
36,959
306,672
The Mud holes
What kind of problems are you having? How many miles do you have on it? Why poolaris? Why not a Yami? If you are truly unhappy, then sell it and move on. Let us know what you get!
