P500 Poll- P500 trouble costs (not maintenance/accident)
P500 Trouble Repair Cost total, (not maintenance )
  • $0
    Votes: 99 83.9%
  • <$50
    Votes: 1 0.8%
  • <$100
    Votes: 6 5.1%
  • <$250
    Votes: 7 5.9%
  • <$400
    Votes: 3 2.5%
  • <$700
    Votes: 1 0.8%
  • <$1000
    Votes: 0 0.0%
  • More than $1000
    Votes: 1 0.8%
  • Total voters
    118
JWB
JWB
2,098
California MD
Bought new Sept. 2016. Have about- I'll have to look, but over 1200miles. No repairs- other than self inflicted damage. No Honda failures. None.
Reactions: Mudder and rocmar
NTC/TAP Transition Member
11,880
90,564
Bumping this.
A
Ahanson
I have a 2015, sanded the engine and trannie, 4000.00 to rebuild. 1000 miles. Lots of dust in eastern oregon. I snorkeled the air intake, ran the intake tubes up behind my head. Put a uni filter sock on each snorkel tube, they work as a pre filter. Dual uni filter in the air box. The stock air intake is right above the drivers rear fender and has to be the poorest intake placement ever seen. My friends 700’s have a similar set up. The 1000’s have the intake up front under the hood, like my buddies Yamaha, where it should be. I built the snorkel out of 2” pvc from the box behind the drivers seat and went up with two 1 1/2 pvc pipes. If you are running in a high dust areas, snorkel your 500 or 700, or pay the piper!
Parts and labor to include crank, all trannie bearings, head, piston, barrel, rings, seals, basicly a new engine and trannie, the snorkel system with the pre filters on top of the snorkels pipes is working well.
Reactions: JWB and trigger
283,181
2015 P500 bought August 2015, 800 miles zero issues, only routine maintenance (2 oil / filter changes). Ride very challenging East TN terrain, some hills so steep can't pull 2nd gear only 1st :)
William
William
1,442
2,889
Flowood MS
I had to change my vote... front diff seal started leaking so I’m replacing it. So v
that’s 2 diff seals and a cooling fan I have had to replace. Not bad considering what it’s been through...
62FA3A0D 9DAC 4637 A62F 76514CC93CB3 0DCAC320 F4EA 490F 8DD7 52AE55A82538
Reactions: JWB and Chooglin
99Burban
99Burban
30
75
My starter went bad around 1300 miles. The new part was about $85 and it took about 10 min to swap out. Dealer parts guy said i was the first that he knew of to have that problem.
Reactions: Gassygordo
William
William
1,442
2,889
Flowood MS
Is that from submerging, or mud, or did these components just fail?
I go through mud and water... the seals had sand in them... I’m sure it didn’t help.
Reactions: JWB
BuckCreek01
BuckCreek01
279
488
Griffin Ga.
No actual Honda issues to date but it's fairly new (2018). A stick punctured a front CV boot so I installed guards.
Based on this thread and forum, I anticipate many trouble free miles. Fun shall be had. I look forward to meeting @Mudder and running some trails.
Reactions: Mudder
JCart
JCart
895
2,024
Kamloops, BC Canada.
Bought ours autumn of 2014, around 3600 kms 2200 miles I think. Regular maintenance that’s it, tore 1 front and 1 rear axle(s) boots from sticks. Typical Honda reliability, beauties little rig used mostly for work.
j
Red500
Red500
6,609
70,985
Greeneville, Tn.
$0 so far.
Other than replacing factory tires at 1200 miles, alot of that on the road, and they still have some life left.
Reactions: Mudder and JWB
Chuckie3
216
408
New Fairfield ct
Have a 2017 first winter plowing snow with it no problems at all started every time ran great even in below zero weather
Reactions: Mudder
JWB
JWB
2,098
California MD
Just about 2000 miles and two years old now. ZERO Honda related failures. It just starts and runs the same as the day I bought it. Every time.
Had to change my vote: The little micro switch under the 'upshift' paddle failed about 10 miles after I posted. Was about $75 for the switches- they come as a set, and pretty much 'plug-n-play' Took about 15 minutes to change. The little metal arm broke off. If I had been far from home- I was in my driveway when it happened- I could have popped the cover off the paddles and still used the switch enough to get me home. 2156 miles to date.
Reactions: trigger and Mudder
