P500 Post your front bumper/winch mount pics.
Slim
Slim
14
76
Nor-Cal
Strong Made bumper, with light bar mounted on it,
Kept the Warn winch mounted down below
Before
6C69C245 CF46 4A2C AAFD 244E6329427A
68B612D1 ECA8 42FF A154 C1BEFF838BFF
After
0EBCE15E DE64 4930 A510 4A74EA26E7A9
78254A0A 2C38 49F3 8077 B537F70D7D58
3324F567 9491 471D A6C5 89CF0E124239
EB003944 8B4E 4C3A 8E89 C980BC8CE444
chrisC
chrisC
138
259
Newfoundland, Canada
20160102 122840 20180516 154039 20151227 120710 FB IMG 1526495049370
homemade front bumper with receiver for shackle. I also have a mount for a chainsaw and a small generator that goes in in the receiver..
the rear winch is great when you really don't want to go any further... while your riding without another machine with you
TeamCheap
TeamCheap
243
454
southeast michigan
  2. Other Brand
HP5NC
252
284
NC
Strong-Made bumper - Superwinch LT4000ATV (Synthetic rope)
Dash mount control and remote plug-in under left drink holder.
How do you like that SW lt4000 synthetic? That’s one on my short list. Only thing I hate about the superwinches is the YELLOW. Also on your strong made bumper is there any reason why a winch can’t be mounted in behind the bumper with the fairlead on the outside of the bumper??? To me that’d be the perfect setup. I can’t decide which way to go. I may go Honda oem bumper with KFI mounting plate. If that option works. But yea I’m very interested in the winch you have.
HP5NC
252
284
NC
I like this setup as well. Is this a custom?? Nice bumper beefy and winch mounted behind the way id prefer. But from the looks of thing may not be able to achieve. Either strong made with winch on top or oem Honda bumper with KFI mount, the strong made with winch underneath looks good on some of these on here.
Reactions: Dp5hunter
DaddyDubbs
DaddyDubbs
15,418
145,492
So far I’m happy with the winch, worked great at Takeover when I high centered in a mud pond ( actually just a Big puddle). I don’t object to the yellow, but I guess you could always spray paint it. The Strong-Made bumper is a clamp on, not sure if there would be enough room for a winch behind it. Sorry, can’t speak to the KFI or Honda OEM bracket.
HP5NC
252
284
NC
I think the SW LT4000 synthetic is like 215 bucks on amazon it’s not a bad buy at all. Do you know the difference between the Terra’s and the LT??? And yeah I suppose the yellow dial could be spray painted...does it come off? A dark dull orange would look good I think with my olive
DaddyDubbs
DaddyDubbs
15,418
145,492
Sorry, I don’t know the difference, I know a lot of people here have Terra’s, maybe they will chime in.
Bottom line: Any winch that you use, if it works and gets you out of a jam will be on your brag list and you’ll swear it’s the best thing out there, if the motor frys or jambs up you’ll likely swear at it saying it’s the worst POS you have ever seen.
196,132
Did you use your tree saver? :D
DaddyDubbs
DaddyDubbs
15,418
145,492
Nope, didn’t need too, you were my rock and anchor getting out of that mud hole (Thanks again!) :D. Hope you’re never in that situation, but I’d gladly be first in line to return the favor. @Mudder did get to use his earlier that day on the same trail, they do work quite nicely. Looking forward to riding with you two and the rest of our group again.
DaddyDubbs
DaddyDubbs
15,418
145,492
On a side note I was blessed with a granddaughter yesterday “Isabelle Marilyn” so the question is - should I see if I can change my screen name to PopaDubbs or OpaDubbs (German for grandpa), or just stick with DaddyDubbs?
HP5NC
252
284
NC
@Slim I like that setup strong made looks good with the winch under it IMO. What size tires you running? The winch doesn’t look that low I’m the pics. I think I’d do the same-strong made with winch under it or Honda bumper with KFI mount. I can’t decide
NTC/TAP Transition Member
11,880
90,564
Went with winch on top of strongmade bumper, thinking if ever in deep hole or front end in a ditch. So many options out there. Pretty solid so far. Tree saver is HF 2x6 lifting strap, also have the 20 foot recovery strap for towing if needed.
9A2F032D DE15 48F4 BC17 1832E236C4CF
DaddyDubbs
DaddyDubbs
15,418
145,492
Like @Mudder I mounted my winch on top of the Strong-Made bumper, glad I did when I got hi-centered in a knee deep puddle at Takeover, at least I wasn’t noodling for the winch line. Thanks again to @trigger for the anchor to get me out of that one :D
196,132
Anytime Dubbs. Your winch did all the work I was just something to tie on to. You were in front of me and I wondered why you took the line going through the water? There was a narrow shelf on the left that I took to get around you. Did you see someone in front of you make it through that? I think you just wanted to go through the water? :cool:
DaddyDubbs
DaddyDubbs
15,418
145,492
Right, you were my anchor. Honestly I didn’t see the shelf on the left (gray hair moment :eek:) I thought everyone was going straight through, at any rate I’m sure Pam wasn’t looking for a mud pedicure right then, but I’m grateful I could hook on to you to get out...Would have been a B if we were alone. Thanks again, what a great day.
drob8904
42
164
Ontario Canada
