P500 Power draw issues
N
NHpioneer500
20
14
Hillsborough, NH
I seem to be having power issues when I run the winch. Everytime I draw the winch in with my plow attached my overhead radio resets. I just swapped the battery out for a new one since the factory one was dead. My local parts store only had a 14amp battery replacement, the 16 amp was too big. Could that be my problem or do I have other issues? Radio is wired to accessories harness I believe.
Reactions: rtn001
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Really need a second battery for your wench and acc. The stock battery just can’t take the amp draw and voltage will drop below the needed to keep your radio settings.
Russ989
Russ989
22,645
147,291
I agree
NTC/TAP Transition Member
11,883
90,593
Have the MTX audio pod and just experienced a similar thing winching, but mine muted until I turned it off/on.. Some radios have a narrow operating voltage band. Given the few times I winch, and don’t have a plow, I’ll live with it. When I had a bad voltage regulator that spiked at 18v, radio also went out.
Reactions: rtn001
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Did you try it without the winch attach to the plow..Might be a weak regulator..
Reactions: rtn001
