P700 power steering question
SuperATV
SuperATV
1,784
13,122
Madison, IN
www.superatv.com
Its a game changer. You'll never drive another machine without it.
Installation isn't too bad. Its about a 4-5 beer installation. The worst part is the removal of the plastics. Everything else goes together pretty easy. Just leave everything loose until the very end, make sure its all engaged, tighten it up, crack another beer, and drive.
And hit me up before you order, and I'll get you the member discount code.
Crazy Truck Driver
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
consumption may vary i think someone said they did it in like 3 hrs good thing is i dont have to jack mine up or remove anything but some plastic and the steering itself. got like a ft and half gap between the tire and the fender
It does all but eliminate the devil steering for sure, I’d never have a sxs without it again. I didn’t take tire off when I did it. Pretty easy but like SuperATV said leave everything loose until the end.
Reactions: SuperATV
Russ989
Russ989
22,645
147,291
ok so i have the ole basic model 14 700-4. iv seen people putting the power steering on and kinda looking for their response .
how much difference does the power steering help with bump steer?
I never had it on my 700 but my 1000 has it and now I don’t think I could live without it!
A
av8or
Getting pretty close to pulling the trigger for power steering. Would love that member discount code SuperATV mentioned.
SuperATV
SuperATV
1,784
13,122
Madison, IN
www.superatv.com
Dude! HUGE Black Friday sale starting tomorrow! Get it then. Way bigger discount than I can normally do with the basic forum member discount.
Reactions: Mudwing
William
William
1,442
2,889
Flowood MS
I drove a deluxe 700-4 tonight and I must say... I am not spending $500+ on power steering for my base model. Just not that much difference when moving to justify price.... BUT... I will never buy a new one without it again... if that makes any since at all...? It is noticeable...
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
makes perfect sense to me if i didnt have portals id never even think about it. but i still might not going to lengthen my portal bracket steering arms to reduce steering angle. at the see time will make it easier to turn. i drive it with 1 hand right now with portals and no power steering a little forearm action sometimes for a little more support.
Reactions: William
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
i wont be needing it. i changed the steering arms on my portal brackets and its is sooooo much better now
Reactions: Mudwing
Buggyman
Buggyman
47,988
376,356
ne. ohio
ez steer added to my pioneer 700-2 big improvement, like trimgauge1 said it will take a few hours also I did not remove steering column or the fender. makes plowing and tight quarter maneuvering a one finger job.
