P1000 Pull pal equivalent
K
Kelldog
55
120
Need something much smaller and less spendy. What have you made or found
Reactions: Lady01
rickoshea
6-8 ft. of chain.lay it in a v with the v facing you as far from you as your winch cable allows.pound 6-8 pieces of rebar through the links on each side.won't work that great for sand though unless your rebar pieces are long.works great otherwise.or you can do a deadman,which is too much work.
Reactions: Lady01
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
What kind of environment are you usually in? Mud, snow, sand, etc...
Reactions: Lady01
