Talon Purchased green Talon r today
L
Lovetorque
68
80
Columbia falls mt
Was able to locate a talon r in miles city Montana today I’m leaving Kalispell tomorrow morning I’m heading back to Illinois to pick up a new enclosed trailer driving further on to Baltimore Maryland pick up a load of rental equipment there heading back to Miles city and then coming back to Kalispell Montana with my new talon r we don’t pay taxes in Montana total cost out the door 20,700 a little bit below list no freight no set up it has 5 miles on it and all the nubbins are still on the tire They check to see if there was recalls on this concerning the roll cage and there was not
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Tomorrow should be good day congrats!!!
Reactions: Plumber32
BWAF
BWAF
8,857
42,437
Carthage MO
Thanks I did Honda financing 3.9% 3 years I will use this for Business But I will probably have to go out and test it several thousand miles to make sure it’s going to hold up for business use . Will try to do 4900 mills in five days
Keep us updated
Reactions: Plumber32 and sharp
bigblueaz
bigblueaz
67
Arizona
Welcome from Tucson 4900 miles in 5 days?? Crazy
bigblueaz
bigblueaz
67
Arizona
I have a 2014 wildcat that has 1700 miles on it. I bought it used in 2014 with 1400 miles on it. Guess I don’t ride enough
L
Lovetorque
68
80
Columbia falls mt
Wow, I drove 21 miles one way to get mine and drag it home, congratulations on the new machine.
Well I managed to do 1135 miles today going to sleep for five hours and get up and do it again tomorrow I’m not driving 4900 miles just to get the talon is basically a work trip the talon is the final stop
103,581
Love the west Glacier area.
where do you ride around there?
L
Lovetorque
68
80
Columbia falls mt
A lot of back roads , well the 5100 mile drive is complete did it in 2 hrs short of 5 days . Have 50 miles on the r . It soaks up the big stuff fine but the small stuff is a bit harsh, rear needs more rebound comtrol for sure. Fit and finish is good ,installed poly front with vents, Honda did a Excellent job of making the rubber gaskets and seals fit extremely well the quality of the front windshield is quite nice I also purchased the back poly windshield versus the cloth windshield the fit and finish again is very good in all connecting points, winch install was simple and easy to do i used the stock bumper it works just fine don’t know why you would have to have an aftermarket bumper as someone else mentioned though when putting the wires on the distribution block put the yellow and blue one On first doing the Black and red first will make things difficult there’s also a red wire in the battery box that has to have tape cleaned off of it and installed to the top post that is readily available to except the wire. If you were doing winch install and windshield at the same time do your winch first or you will be removing your windshield you have to remove some bezels underneath the hood to do the winch installed, When installing the winch you will also have to remove the glove box do not put the glove box back in until you have taken the wire off the back of the 12 V accessory port The wiring harness needs to be attached to the accessory port and the stock plug in the main harness. Also purchased the center bag the corner roof bags the bags are nice quality is excellent zippers on them also purchased lower door panels in lower door panel bags but there was no lower door panels in so I did not get that part finished
105,455
Welcome from the Great Lakes State.
We need pics pics pics! :D Or it didn’t happen.
Sawpilot
Sawpilot
57
151
West Virginia
barnwoodbuilds.com
What a great machine, live n ride in West Virginia bout every weekend. Great times, found my Talon at Cumberland md
902BA165 D1B6 46E5 B6EE D9D950C92EEC
EF1B271A 9A4D 4A86 90D5 6E9E144542B4
B7DBF7C0 B529 476A AB17 768ECFCEC34C
D43246F6 6418 4643 8333 6B64F0C561A0
07C60D1A 92C6 45F5 80B8 BF0747C1ACFA
4CA30D3B A8B0 4A3B 88A7 BAC238061A22
239B015D 0919 4622 A23C C8A71B9F9F43
bigblueaz
bigblueaz
67
Arizona
What stereo setup is that? And do you like it?
Wife wants a decent stereo with good bass and Bluetooth
Bigblue1
77
92
NC
Cheap o off eBay slim style but they last for years this was 38 inch I like to sodder them into my highbeam wire, it makes for a better cleaner install without other switches
What did you use for brackets ? I just installed a curved 42 last night that actually measures 43 from Amazon and ended up with Polaris brackets and fits perfect with the glass windshield .
Reactions: BWAF and bigblueaz
