P1000 Putting engine oil in dipstick hole (My Bonehead Move)
P
P1000Paul
11
Arkansas
Can anyone tell me what harm there is in putting a quart of engine oil into the engine oil dipstick hole on a pioneer 1000?
I wasn't paying attention and intended to put that quart in the sub transmission hole which is under the seat. I fully admit it was a bonehead move. Yes, I now have 7 quarts in the engine area and I'm sure I'll need to drain a quart out.
Just need to know if there is any other potential harm I have done? I have not started the machine since the oil was put in.
207,989
Don't think you have done any harm, it's just a pain to get the over fill out, I tried to remove filter and drain it out, doesn't work. So drain a quart out of the engine drain plug, pain in the A, but's the only way I found. Been there done that!
P
P1000Paul
11
Arkansas
Thank you Smitty for the reply without making fun of me (which I clearly deserve!). I'm ok with the pain in the A. It will remind me to pay greater attention to what I'm doing in the future.
107,322
Hay man, chit happens! We all make mistakes. Ive made my fair share of them. What u did wasnt that bad. Just drain what u can, recheck it and add if needed. All will be fine. 👍
63,988
Ya. No harm.
Just allow time to it to settle before cranking.
Many fill through the dip stick. This is ok as long as you allow it to settle.
Your actually filling the crank case and not the oil tank as you should be.
Imigian the damage that could occure from a way overfilled crankcase when you try to start it immidetaly after stuffing it full of 6qt's of oil.
63,988
Guess I didn't read the whole thing. Lol.
Ya. Need to remove some.
Best method would be to siphon it out. Use some windshield washer tube, stick it down in then blow air across the other end. It will pull it out and into a bucket if below the machine.
L
LarryAmboy
894
1,979
Castalian Springs, Tennessee
Get one of these to extract the extra quart.
P
P1000Paul
11
Arkansas
Thanks for the idea and thank you all for the input.
I ended up letting about a quart out by very carefully loosening the forward drain plug to the point just before it was completely unscrewed.
Oil drained out slowly.
The engine oil dipstick now shows an oil level 1mm above the full mark on the dipstick
I still have not yet started the machine and am going to let things settle out overnight and check the dipstick again in the morning.
I’m guessing you all think that is a reasonable plan?
P
P1000Paul
11
Arkansas
To clarify - I originally put 6.1 quarts in the correct oil reservoir fill hole. I then mistakenly put a single quart into the oil dipstick hole that *should* have been poured into the sub transmission. So, only a single quart went directly into the crankcase.
Reactions: Lady01
5,048
22,628
Yep, sounds good to me.
