Talon questionable steering.
ThunderChicken
ThunderChicken
69
145
BATH
1st time out on my new talon x. Rode over a hundred miles in WV this weekend. A few times I seemed to notice what I would call questionable steering response. It seemed to be fine when turning right. the least little movement of the steering wheel would turn the wheels and you would go right. A few left turns it would seem to take a lot of steering wheel movement to go left. Almost a sloppy too easy feel to it. then it would seem to correct it itself. didn't seem to matter what terrain rocks, mud holes or 50 mph down the highway. most of the time it was perfect other times not so much.
Reactions: Isaiah and BWAF
MFG
MFG
191
293
East Texas
check your front end alignment. A bunch of Talons where delivered with the alignment way off. Mine was a good inch to two inches out. I set mine at zero but an eight inch towed in would not hurt.
208,729
Not just Talons, all there S X S's!
Reactions: BWAF
HondaTech
I've had a few Talons that have had the wheel rub the A-arm due to the steering rack being out of adjustment left or right.
Reactions: 1HasBeen
F
Fyathyrio
245
675
I read this question this morning, and was gonna give a smartass response of some sort, but went to vote & then hit the trails instead. For whatever reason, this question popped into my head while out riding.
What it sounds like from your limited description is under-steer, the front end sliding instead of turning while on slick or soft surfaces and when off the gas. Try hitting the gas next time you feel that, a little gas and it'll be neutral, a lot and the back end breaks loose and comes around nicely.
I doubt it's mechanical since it's intermittent, and the only on left turn issue could be a comfort zone thing where you're subconsciously more cautious on left turns. (Mine is lean angle, I don't like right hand as far as left hand lean)
Embrace rear steer, slow down before the turn, downshift, stomp gas to bring rear around, squirt out down the trail. Works best in 2WD.
69,273
Make sure you didn't bend a tie rod.
Reactions: Isaiah
ThunderChicken
ThunderChicken
69
145
BATH
sorry if its seem like a strange question. it just isn't consistent. That's what has me baffled. no sliding of the rear end no slippage of the tires on slippery surfaces. Sometimes even on the pavement. just the slightest right turn of the wheel and it moves right. Then some left turns it takes almost 3/4 of a turn to get any left hand movement. BUT its NOT all the time thats whats confusing. Could all be in my mind. Getting first service tomorrow. I'll have everything checked then.
Mothgrey
Virginia
Hey Thunder I just took my Talon in for service. I'm having a steering issue also. Mine I felt the fist time a week ago in WV I was on the road and about 1/4 to 1/3 turn to the left the wheel was fighting me like it didn't want to turn. Then it kept doing it. I took it to the dealer Saturday and when I unloaded it I put it in park and turned the steering wheel it did the same thing sitting still. I had the guy checking me in feel it also it was there turning right also but not as bad. It felt like it was trying to get past a bad steering knuckle or one at a bad angle. I'm hoping to hear back this week.
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
I agree alot of them have been out alignment, but it should be that way alway so that is concerning when it is happening only sometimes.
Reactions: Isaiah
robman
robman
21
32
I read on one of the facebook talon groups that it could be caused by low voltage from the battery. He said the voltage would drop to about 9 volts when turning the steering wheel while driving. You may have a bad battery. That's what I got from the post.
Reactions: IDIOT and JTW
208,729
Wow! That would be a simple check and fix!
Reactions: IDIOT
That would make sense as it’s an electric assist PS system. It wouldn’t be the first time bad batteries from Honda have caused some weird issues.
Reactions: Mudder
PaulF
PaulF
1,462
4,815
Don't forget about lose/rusty/corroded grounds too.
Reactions: Mudder
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
If you are still a member here, What did your dealer say about this?
208,729
It's an additional charge if you want a Honda alignment right!
208,729
Find a dealer who cares and you wont pay a dime!
Got any suggestions around NW Arkansas? After Honda comes out with a Pioneer with suspension and added HP, I will start looking, if I haven't bought a Yamaha by then! I really think Honda is really stupid with the Talon, too much gizmos to go wrong!
