P1000 Questions about adding a horn
67,659
I have a P1K5, and it says on the ad that it is compatible with it... trying to find out how exactly...
Looks like I need to stock them.
I can't seem to find the male ends at all.
I can have one maybe early next week that should fit.
That connector is not found on any Hondas. But chopping it off would make it universal.
Tie
Tie
35
110
Toronto
Thank you for checking. Thinking I will just cut the connector off and wire it in to the fuse box or bus bars. I will update, hopefully with a success story!
Reactions: Smitty335 and CID
Tie
Tie
35
110
Toronto
Thank you for all your help and suggestions along the way. I think I have the dual battery and the horn installed. Some challenges along the way, but nothing insurmountable - I hope. Next will be to go for a ride with the new modifications.
It is really tight getting hands in under the dash... wow.
Placed the horn above the left front wheel, I found a couple bolts that I attached it to that hold the body in place.
Only disappointment is the horn button that doesn't light up. It lit when I tested it, but when I actually attached the wires, no light. Puzzling.
Horn Voltmeter Horn placement
Reactions: StewB and CID
