P1000 Quick release steering wheel
saw1
37
83
Fallon, Nevada
I found quick release hub from DragonFire Racing that will fit the Pioneer and wonder if any forum members have this device on their P1K. Could this be used as theft deterrent if the steering wheel was removed when it was stored or traveling to and from rides. I have good insurance but I'd still rather not lose mine to thieves.
Reactions: CumminsPusher
66,869
Hum... I don't recall anyone with this, I do remember a few changing out the wheel with a different one tho!
Post more details if you will. Thanks.
322,690
93 accord hub (along with all models related) fits the Pioneer. You’ll save quite a bit without buying a kit. I did originally buy a quick release setup but decided not to use it because it placed the steering wheel 1/2 inch towards the driver so paddles are harder to comfortably reach but it’s still a direct fit. Used a roller horn contact from an old Dodge truck on the backside to make horn work. It was worth it, aftermarket wheel is way more grippy and comfortable.
21C386F9 DBFC 4D71 BB93 6A90578A6B17
98DB6E9E 9256 496E AB6A 89223F088C0A
B7AAC8F4 955A 48C7 A66D 95F9700A3877
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
View attachment 78033 View attachment 78034 View attachment 78035
Didn't you have to machine the adapter slightly? I think I read that in the build thread?
Or was this a true bolt on affair?
322,690
For the horn to have clearance to be usable 1/8 has to be ground from the steering shaft. I did not do that with this machine (no horn yet) direct bolt on.
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
@CumminsPusher or anyone close to their machine.
What diameter is the steering wheel?
322,690
350mm is closest. It’ll allow seamless use of the paddles. I’ve got both 320 and 350, 320 is better in the really tight stuff that we like but it takes a little getting use to the paddles sitting out just a bit.
Need to use the narrow adapter hub.
322,690
Still surprised no one else has done this yet, it’s cheap and easy but make sure it fits those cars because it’s a small shaft, not many take it, took a bit to figure out what makes will work.
I bought that cheapy hub just for the rubber boot so it’s a nice finish to the dash, worth it for the money and slipped right on the narrow hub. So still buy that for looks, just use the boot and toss the long hub.
That hub is too long you need the short hub like below then you just need adapter for the horn button like the bottom pic.
B3914A03 9C9C 429B B406 D47350B58053
Steering Wheel Short Hub Adapter Billet For Honda Civic Accord Acura | eBay
A747A50E 439F 4AA6 A6B5 1B63062CD72B
100% new Steering Wheel Spacer Hub Adapter Kit Black for MOMO to NARDI PERSONAL | eBay
Those 3 parts for under 50$ gets you hooked up for any steering wheel you want and is reversible to factory if needed.
322,690
I did forget that I ground a little off of the hub adapter so @Neohio you memory was right but no machining at all. Wanted to make sure info was accurate. This was done to get paddle spacing to steering wheel correct. There was a lot done to Puddle Jumper in that month so memory was off :)
67898563 1E8A 4652 AF0A 080B5D27F139
P1000 - Cumminspusher-the New Ride
Reactions: MadMikeV and mjn
Neohio
Neohio
Beast of the East
14,586
73,811
Painesville Ohio
Appreciate your help @CumminsPusher. This is on my want list. Will order and throw the adapter on the lathe at work to machine that step off.
Biggest ordeal will be settling on a wheel style.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,789
183,378
Grand Junction, CO
Before getting a quick release wheel, consult the Dale Earnhardt Jr. on how to make sure it does not come off at speed.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Good info in this thread.. I have the DFR quick release hub & DFR wheel on my Viking. I planned on going with the same on the Pioneer. However.. if it spaces the wheel back too far, I'll look at the Accord set up. I really like my DFR wheel though..
Mine is the "shallow" model.. is that the one you tried @CumminsPusher?
322,690
It is. Might be out now but at the time I couldn’t find a small one with internal hub that bolted to steering stem. Only way to go was to bolt the release to the small hub which pushed the wheel an additional 1/2” off the paddles. I wasn’t worried so much about the release just wanted a comfortable wheel.
mjn
mjn
1,409
5,206
Yea, I'm with ya. I cannot recal ever utilizing the release aspect of it. What the heck am I gonna do? Carry it with my while we hike?
I don't think so.
mjn
mjn
1,409
5,206
@CumminsPusher You said you tried the quick release kit... was it the Dragonfire racing kit? I was just looking on the DFR site (trying to remember how much I paid for the darned thing) and it LOOKS like the Viking and the Pioneer take the same kit.
My question is; The wheel I have now is the DFR "shallow" suede wheel which you said is the one you tried. It has about a 2" dish.
If I got a 350mm FLAT wheel.. do you think the paddles would be close enough to use properly?
mjn
mjn
1,409
5,206
I stated this in another thread, but I just found out the Pioneer takes the same DFR kit as my Viking did.. in other words, I have the kit, and the wheel.
I checked my wheel against the OE one, and they are the same diameter. We'll see if I like where it places the wheel in relation to the paddles. Hopefully I can get to that on my next day off.. we'll see.
322,690
Awesome news!
