P1000 Radiator
  • Thread starter Billthefirefighter5780
  • Start date
6
10
ny
On my Honda 2018 1000-5 My display says coolant low actually it just says low my overflow is filled to the Max and it did not overheat Could this be a bed sensor or just low temperature
Reactions: DG Rider
41,791
If there's an actual sensor in the tank (as it sounds), it's not unusual for those to stick. Try tapping it lightly.
Reactions: Remington
Lofar
Lofar
11
12
NV
youtu.be
The "lo" you see on the cluster means the engine isn't up to temp yet. Let it idle and it will change to 1 bar, then a second.
Yes I see this all the time. Once it warms up it goes away. Also, I do not think there is a sensor that measure low coolant in the tank is there?
70Bones
70Bones
888
3,779
New Brunswick Canada
Yes, as mentioned above, lo refers to engine temp, not antifreeze level. There is no antifreeze level sensor in our Hondas.
