Anyone else get a recall letter concerning "standards", states that all 4 shocks would be replaced as a result and would lose an inch of ground clearance, dont know about you's but im not overly excited about making the p5 even lower lol
Thanks i missed that one
The shocks are also available to US owners, in the letter it says if you are not satisfied with the sticker to see the dealer and an alternative fix is available ala the shocks. It slightly lowers the COG to comply with the standards. Going to a bigger tire defeats changing the shocks. FWIW.Yep just came in the mail today. Lowering it 1.1". Parts available spring of 2016.
Based upon your statement on lack of gtound clearance I take it you have not owned a rzr800 50". I can tell you firsthand that 50" rzr had considerable less ground clearance than the p500. I had a 2" lift and 27 " tires, and dul rate springs on the rzr and it just equals the P500 with only 26" tires on it. The 50" rzr stock was a belly dragging rock magnet. So to say the ground clearance on the P500 is abysmal is a mischaracterization compared to the other 50" sxs.Got my letter today stating I can get new shocks that I want no part of, condiering Honda was last into the side by side market this is unacceptable. The 500 was worse than average clearance and now they want another inch well they can shove there shocks somewhere other than my bike. We should be compensated for them selling us a untested product and if the upgrade is done it's not as sold or advertised.
I'm no expert but it looks like you can adjust the preload up all the way and be at the same height you were before with the old shocks.Here's some pics old to new. I haven't had it done to mine.
View attachment 12894 View attachment 12895
It's the same shocks that are on the rear.....I'm no expert but it looks like you can adjust the preload up all the way and be at the same height you were before with the old shocks.
edit: but it also looks that may make for a stiffer ride
