P1000 Recalls Installed - My Take
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
Had all the recalls done finally - Here is my take on it
Clutch - Great Improvement
Muffler - Great Improvement
Throttle - Great Improvement
Heat Shield - Burn my Ass - I think it should be called ass burner! I guess we need to change that
7,352
29,432
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Add a fan under the seat and that will a LOT with the heat under the seat.
208,719
You outa come out with a fan kit for the heat issue, not complete automatic because the heat is nice in the winter, maybe a three way toggle, manual, auto and off! I'm going to take all the heat shielding off under the seat this fall. Was reading some where on the forums about an ECU getting to hot and freaking the P1 out, mine freaks out every once in awhile, no codes and smell gas if I'm running hard and shut it off and forget to turn the fan on, think it just gets too hot
Redmoon
Redmoon
265
456
Prescott Az.
Smitty could you explain "Gas Smell" a bit more? What you think the cause is and the potential affect from it. The reason that I ask is while out riding my new machine the other day I noticed a gas odor several times and just thought it was a wind change and exhaust blowing back in the cab. Temp never went over 2 bars, fan ran normal. Thanks
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
We will be defiantly be looking at this! We also are working on the bed rattle
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
IN AZ we don't need the extra heat and When I am out riding and my butt is bright red(burnt) from the heat shield there is a problem!
I did it for like $50 so I'm sure you could make a nicer kit your cost $100 and sell it for whatever and people would pay it. My kids said it was night a day difference in the back seats. You could make it so it pushes and pulls add some drill out vents in the floors/sides that would make it so it would also work as a heater the only thing that I could see is that you may need the fan to turn slower in heater mode. (Just friendly advice)
I'm sure you have seen this but this thread has all the info needed to do it. (I think the hardest part would be making a bracket to install the fan if you were going to make it really nice but a few zip-ties will do the job just fine)
P1000 - Tried and true cab heat fixes-2018
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
Pics or it didn’t happen!
ThidOIPyncaCnyCj7sTaPL8D24yJwAAAAw226h174c7o5pid1
russknight
russknight
1,910
7,508
Perry Florida
I have a 2016 EPS. If I take it to the dealer will they do all of those on request? What difference did the trans mod make?
Thanks!
Reactions: Plumber32
7,352
29,432
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Thanks!
Yes the dealer should do all on request. The clutch may take some time to get the parts ,but if you have a good dealer you should have no problems.
The trans update is a must. Dont think we have had any clutch failures after the update.
The peddle and muffler sheild is a saftey issue.
The heat sheild does help bit if you search around the site most have had the Honda fix and kept or added more cooling options.
The fan ECU update doesn't cover the 16 models.
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
Thanks!
The trans made a huge difference , sorry forgot to put that one, I called our dealer they ordered all the recall parts and then my 1000 was in and out in 1 day.
208,719
I think when the gas tank gets hot it lets vapors out of the vent line and I haven't extended my vent line, yet
Reactions: Landman
russknight
russknight
1,910
7,508
Perry Florida
The muffler shield was done by the previous owner. I installed a windshield shade under the seat and made a huge difference and was a cheap fix. I also have a fan I'm thinking about installing as well. I called the dealer today and they said they will be getting back with me for an appointment time.
Reactions: Tramguage1
Redmoon
Redmoon
265
456
Prescott Az.
Well called the dealer today and the Honda is going back in the shop. I told them Burning my ass I feel is a problem. They want it ASAP they said. Hmmmm what did they forget????
RB3 What year is your 1000-5? And could you post what the dealer comes up with regarding the seat heat? I suffer the same thing on my 2019. Getting ready to put firewall insulation on the engine bulk head for the backs of our legs inside of the engine compartment. more insulation under the seat. And a Walmart $40 bilge fan on a 22k machine. Is your dealer one of the Ride Now Sports?
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
Yes its ridenow, I will let you know as soon as I take it there this week. 2017 1000-5
