P1000 Removing the window cranks hard doors.
slowdryrider
slowdryrider
574
784
Canada
Anyone remove the window cranks on the Pioneer 1000 hard doors. If so how / what do I need to do. Thanks,
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
Okay thanks. I have one and have tried guess I'm not doing it right. Now that I know for sure I'll give it another go.
Reactions: Lady01
Jevanoff
Colorsdo
Did you figure it out? If so I'm in the same boat, tried several things with no luck.
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
Yes they come off same as what the automotive ones do , using the same tool. To help you out insert the tool as close to the crank as you can between the washer and crank. The clip is also parallel with the handle not 90 degrees away from the handle. Use the tool along the handle if this makes sense. Either the same direction of the handle or from the other side towards the handle depending on what way the clip is installed.
Jevanoff
Colorsdo
That worked! Thank You, Thank You!!!!!!!!
